FJ Cruiser 2007 & on
FJC 2WD verses 4WD in ice/snow
Old Nov 28, 2006 | 10:02 AM
Corey's Avatar
Co-Founder/Administrator
Coming into work this morning I used 4WD the whole way.
Lots of compact snow and ice on the way in, the whole way in.
I noticed at stop lights when taking off I would slide a little sideways, then it would correct itself when in 4WD.
Also when in 4WD your traction control stuff via the onboard computer is all turned off.
Later I took a few corners in 2WD to try and spin the tires, and it did not happen.
What happened was there was a clicking noise from under the dash, and even the throttle would shut down on me even with the gas on.
I guess this is the VSC (Vehicle Stability Control) system kicking in.
It was cool, the vehicle was almost trying to slide sideways, it would have if I had done that in 4WD, but the vehicle applied the brakes to the ones slipping, and totally corrected me as I was going into my turn.
I could have taken my hands off the wheel and the rig would have made the turn on its own.
This is my first rig with all of this new fangled computer gizmo stuff, and I was impressed that 2WD was actually better in this than 4WD.
Anyone else get that impression too that has VSC on their rig?
Also when it kicked in an alarm would go off behind the dash and the VSC light would come on, pretty cool.
Old Nov 28, 2006 | 10:09 AM
Nate C's Avatar
Isn't 2wd better in snow and ice than 4wd anyway?
Or am I thinking about 2wd front wheel drive..???
Old Nov 28, 2006 | 10:13 AM
garrett1478's Avatar
thats why you do the mod where you can use 4WD, e-locker, and VSC all at once
Old Nov 28, 2006 | 10:18 AM
Corey's Avatar
Having the VSC and 4WD would be nice, but not so sure I would do the locker on a commute.
Nate, I have driven a lot of 4WD rigs, and 4WD is great for deep powdery stuff and I am sure it would win here over the 2WD with the traction stuff on.
But what I was driving on was about 2" to 3" of pure ice from the compact snow that had frozen over.
This morning temps and still right now is around 24 degrees.
Old Nov 28, 2006 | 10:23 AM
Teotwaki's Avatar
2WD front wheel drive is a PITA on ice. When the front tires lose traction you've lost steering and the drive wheels
Old Nov 28, 2006 | 11:33 AM
04 Rocko Taco's Avatar
You think?!?! I loved my 2WD FWD Ricer in the ice. Granted I live in Atlanta, Ga, and we dont see a lot of ice, but when we did, I loved it. easy on the skinny pedal, and you just wont lose traction...
Old Nov 28, 2006 | 11:58 AM
BT17R's Avatar
Corey, try taking it out in deep snow and forcing it to spin...it won't. Oh, if you overcook it enough it might, but it has to be a heroic entry speed to overcome VSC.
It's an amazing safety system on-road, but can interrupt progress off-road in some conditions where you want wheelspin and can accept some yaw while slogging up a slick climb. I guess that's why it disengages in either system with the center diff locked.
I've read stats from years of analysis of VSC's from different manufacturers selling in Europe longer than here. It's proven to be a tremendous safety device that's even more effective than dedicated snow tires. It's mandated for all cars sold in the US in a few years, and has trickled down from Lexus into most Toyotas as standard equipment now.
I used to object to the nanny computer, but after working it to know what to expect and when, think it will prove helpful for the vast majority of drivers out there. We here at YotaTech, being exceptionally skilled, of course won't need it but can tolerate it for those with lesser skills than ours.
Old Nov 28, 2006 | 12:13 PM
Corey's Avatar
Hi Bob.
Yeah, I have been reading the owners manual at night, makes for good bedtime reading
It says it can get hot after awhile.
I guess that is why it does not work when in 4WD high or low, as we do want some wheel spin at times to make it up a climb.
Old Nov 28, 2006 | 12:22 PM
EWAYota's Avatar
I'd rather have FWD on ice as oppose to RWD on ice. More weight on the front end and grip and power applied with FWD. RWD, all your power is on the rear, which in most cases is light (empty truck bed), and you turn your front wheels and they're just getting pushed straight no matter what.
Old Nov 28, 2006 | 12:37 PM
da_bigg_wigg's Avatar
My old civic did well on ice, maybe even slightly better than the 4runner. Weight is a big thing there...
Old Nov 28, 2006 | 01:18 PM
Corey's Avatar
Played around a bit in the parking lot after I got off work.
I would purposely slam on the brakes and I guess it is the ABS that kicks in.
It would push back up against my foot and make a clicking sound as well.
That keeps you from locking up your tires and skidding into someone.
Next these on board computers will be asking us how we want our coffee on our into work commute.
Old Nov 28, 2006 | 01:21 PM
Elton's Avatar
i found out going up steep hills better to have it in 4wd and flat ground with the locker on it was a handfull with it off it was better in 2wd
Old Nov 28, 2006 | 01:27 PM
or parallel parking themselves... *cough * lexus *cough*
Old Nov 28, 2006 | 02:24 PM
EWAYota's Avatar
When I went from my 79 Ranger to my 99 F150, my first experience with ABS was while I was idling down a muddy hill after hitting a couple bogs. I started to slide off track and hit the brakes and felt a thud thud thud on my foot. I thought for sure I had mud in my brakes causing it to do that.
Old Nov 28, 2006 | 02:51 PM
Mikestang's Avatar
That mod is for 4wd, e-lock, and ATRAC, not VSC.
Does the FJ not have VSC active in 4WD? On the 4R VSC is only turned off when you lock the center diff; you can run 4hi w/VSC (those of us with v8's can't run 2WD).
Old Nov 28, 2006 | 02:57 PM
BT17R's Avatar
Corey, yeah it's the ABS there. I know many object to it for good reason when using aggressive tires in deep snow, but for most on-road situations, I'll take it with. Next time, keep your foot on the brake and steer as if in a slalom. That's the real benefit of ABS, providing the ability to steer while braking on low traction surfaces. It's counterintuitive at first and takes some practice to retrain your instincts to let off or pump the brakes.
It takes great effort to overheat the brake pump. The only time I could trigger the overtemp alarm was in my 4th Gen 4R when using the DAC for about a half-mile on a very steep grade. I don't think we'll ever see an overtemp alarm on our FJ's.
Old Nov 28, 2006 | 02:59 PM
BT17R's Avatar
Yes, M/T only in 4Hi unlocked.
Old Nov 28, 2006 | 03:09 PM
Corey's Avatar
Me having the auto, VSC is only in 2WD.
Shift to 4H or 4L, you lose it all.
I8URSVT
Apr 17, 2016 03:38 AM
urabus
Nov 10, 2015 07:38 PM
Daenerysdad
Oct 1, 2015 07:33 PM
83
18
Sep 21, 2015 06:15 PM
May-39
Sep 6, 2015 01:05 PM
