4x4 indicator switch
Old May 2, 2026 | 05:34 PM
Hitdogg's Avatar
Hey guys. I seem to have a bad 4x4 indicator switch on my transfer case. I ordered a 20 dollar switch off ebay, but it is a tad bit long. Meaning the switch is made even in 2wd. Looking at them physically, it's hard to tell how much longer the new switch is. I think, the part number I need is 84222-35050. The part number that I ordered shows in the listing as a 84222-35090. The connector was different, but was easy enough to switch out with the original, but like I said, it's a bit too long. Anybody have a source for this switch? Or know the correct part number? Its a 1991 4Runner with a manual transmission. Thanks in advance.
Old May 2, 2026 | 11:49 PM
millball's Avatar
Is it possible to shim the switch out some with an aluminum washer or two??
Seems I had to do this once to adapt a switch to a transfer case I was changing out.
Old May 3, 2026 | 03:25 AM
Hitdogg's Avatar
That thought had entered my mind. If you put 84222 in the search on ebay, seems there's several, and some of those come with a washer. I feel confident that would work, just gotta figure out how thick of a washer to use.
Old May 16, 2026 | 12:28 PM
Hitdogg's Avatar
Well I was able to get the light working. Used part# 84222-35090, changed the plug end, and used a thicker washer on the switch. Bobs your uncle.
Old May 16, 2026 | 09:38 PM
aztoyman's Avatar
Glad you fixed it and thanks for following up. Dead end threads suck.
881stgen
Feb 4, 2024 09:55 AM
slacker
Dec 24, 2020 08:32 AM
I8URSVT
Mar 5, 2016 07:20 PM
*23
Oct 2, 2011 09:29 AM
KZN185W
Oct 13, 2005 01:53 PM
