85 Pickup Tail Light Illuminating Reverse Reflector Mystery
Old Dec 15, 2025 | 08:17 AM
Yompkins's Avatar
SOLVED 85 Pickup Tail Light Illuminating Reverse Reflector Mystery
Hey guys,
Since I bought my 1985 DLX Longbed pickup, I noticed that when my passenger side tail light is lit, the light from the tail bulb bleeds through and also illuminates the white reverse reflector as you can see in the images below.
The issue does not seem to affect the driverside which look likes it has been replaced. When I take the reflector cover off it looks like the internal reflectors are very different between the driver and passenger side. Does anyone know which of these is the correct OEM tail light? Does anyone else have the problem of having the reverse light appear to be "on" while only the tail light bulb is lit?
Passenger side with tail light bleeding through into white reverse reflector
Driver side. When the tail light is lit, no bleed through into reverse reflector
Passenger side internal
Driver side internal
Last edited by Yompkins; Dec 16, 2025 at 08:37 AM. Reason: Marking issue as resolved.
Old Dec 15, 2025 | 09:10 AM
Discombobulated's Avatar
If it’s like my 91 I have a piece of plastic that attaches to the lens in the middle that isolates the bulbs, possible you are missing that piece, driver side may be aftermarket and they extended the reflector to butt against the lens instead of having the separate piece. If that makes sense
Old Dec 15, 2025 | 11:36 AM
Yompkins's Avatar
Interesting.... when I bought this from my great grandpa last year, there were some tail light bulbs in the glove box along with a red rectangular reflector. Do you know if the piece of plastic in yours was a semi-transparent red reflector material?
Old Dec 15, 2025 | 02:06 PM
The piece I think was gray at some point in its life but it’s kinda brownish grey probably from the heat of the bulbs and 30 years later. It is solid and not transparent. Here is an image I pulled from eBay to give you an idea of the piece I’m talking about. Pay no attention to the part number on this pic not sure if it’s correct for your year, just showing you the piece I have, it’s the part in the middle of the pic.
But to get that piece by itself will be a task, decent full replacements aren’t bad on eBay, I also see some full units that are OEM but they want the covered in gold price, heck if you wanted to keep it simple you could almost customize some sort of material to separate the reflector….
Old Dec 15, 2025 | 04:32 PM
Here is a used one at a sweet price too you can see the divider in the listing.
https://ebay.us/m/yuFDvh
Just the housings with dividers:
https://ebay.us/m/wiMQCE
Old Dec 16, 2025 | 08:36 AM
Yompkins's Avatar
Thanks guys! I was able to find the taillight shade's on eBay. Turns out the 6th gear garage guy from YouTube is selling some.
Once I get it in hand I will have to take some measurements. Might be a good piece to develop a model to 3d print.
Old Dec 16, 2025 | 09:44 AM
Excellent, glad you found them
Old May 2, 2026 | 10:18 AM
4Crawler's Avatar
I recently picked up some aftermarket rear lamp housings for my '85 4Runner and they have these dividers as part of the main housing. The original housings have that as a separate piece. Mine were black originally, I hit them with some chrome spray paint to help improve the reverse light output a bit.
kschiff
Aug 14, 2013 07:09 AM
SR5
Feb 3, 2009 05:09 PM
Belize Off Road Team
Nov 29, 2008 06:32 PM
sutlTL
Aug 19, 2003 07:18 AM
