3vze EGR delete with AC question
Old Oct 30, 2024 | 05:02 PM
Renegade15's Avatar
I read all the posts I could find, watched several videos, none addressed what to do with the line that runs from the VSV on the AC idle up valve over to the airbox? Everyone says to get rid of the little secondary box where that hose connects…but it appears it is indeed still needed? Can I just remove the secondary box and connect the idle up hose directly to the main airbox? For reference, this is the vsv and idleup valve I am referring to, it is to the front of the vehicle of the other vsvs for pair, fuel press reg, and EGR…
thanks!
Old Nov 1, 2024 | 06:59 PM
Renegade15's Avatar
I’ll just answer my own question in the event that anyone else has the same concern. I took off the little triangular airbox still and connected the larger port on the idle up valve directly to the air box with a cap that I drilled to accept a 3/8 barbed union and connected the hose to from the idle up valve. It’s not glamorous but it works for now…I’ll tidy it up eventually…or not!
Old Apr 30, 2026 | 09:53 AM
Shelka04's Avatar
HI hey are there any more pics you could post regarding the vacuum line routing on the passenger side of the engine. Also OK, so you pulugged the opening on the air cleaner and put a nipple on it that then fed over to the passenger side. On the a/c idle unit which of the two larger hoses there did you feed the new line into? And the old line you just capped at the manifold? I suspect a few pcs would address my questions. I did an egr delete, seriously thinned down the vacuum lines on passener side, removed triangular air box and now there is no idle change when a/c button is pushed in. AND to make it worse this is for a Winnebago model that we drive around the country in and the wife is giving me the stink eye.
Cheers, -John
Old Apr 30, 2026 | 09:53 PM
Renegade15's Avatar
I won’t be home until Sunday but can get some pics of the passenger side for you.
Boogeyman
Apr 21, 2024 08:04 AM
Jpl00311
Aug 6, 2023 11:06 AM
Bills86e
Dec 5, 2013 04:26 AM
kingbrian
Jan 13, 2009 05:08 PM
sincal
Aug 13, 2008 06:46 AM
