Wiring Harness Grommet
Has anyone managed to source a grommet that goes in the firewall of a 1985 truck and fits around the wiring harness behind the drivers side fender? If you did how did you mount it on the harness?
It seems although there is zero rust around the panel seams I am getting water in both through the perished grommet, and also through the seam directly about it. Pictures attached. I am going to cut out all the old seam sealant and reseal the seams, both sealed and not from the factory. There is some cracking of the nearly 40 year old sealant in several seams behind the fender.
Traces of a leak under the grommet and in the seam above it.
Grommet is well past it's sell by date
Various cracks in the sealant behind the drivers side fender
I looked around in the past and didn't find one so I just covered it at the time with Seam sealer .
Recently I used one of these on another project and it may work for a 4runner/ pickup.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
I got a 4 pack on Amazon. I may try one some day but would have to disconnect all the wiring to run it through.
That might work, but will need the wiring harness to be disconnected at the connectors to be passed through. I am always worried about breaking the plastic parts at 39 years old. I am trying to find a regular grommet that I can cut and then superglue together once it is over the harness. Failing that I will use a plastic grommet and seal it with marine sealant and try that. After removing the passenger fender I now need 2 grommets!
westfalia
01-08-2022 05:38 PM
tha_joker
11-06-2011 08:23 AM
