Wiring Harness Grommet
Old May 26, 2024 | 05:09 PM
Dieselmann's Avatar
Has anyone managed to source a grommet that goes in the firewall of a 1985 truck and fits around the wiring harness behind the drivers side fender? If you did how did you mount it on the harness?
It seems although there is zero rust around the panel seams I am getting water in both through the perished grommet, and also through the seam directly about it. Pictures attached. I am going to cut out all the old seam sealant and reseal the seams, both sealed and not from the factory. There is some cracking of the nearly 40 year old sealant in several seams behind the fender.
Thanks
Traces of a leak under the grommet and in the seam above it.
Grommet is well past it's sell by date
Various cracks in the sealant behind the drivers side fender
Old Jun 12, 2024 | 03:05 PM
Damion812's Avatar
5 Year Member
I looked around in the past and didn't find one so I just covered it at the time with Seam sealer .
Recently I used one of these on another project and it may work for a 4runner/ pickup.
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
I got a 4 pack on Amazon. I may try one some day but would have to disconnect all the wiring to run it through.
Old Jun 14, 2024 | 12:43 PM
Dieselmann's Avatar
That might work, but will need the wiring harness to be disconnected at the connectors to be passed through. I am always worried about breaking the plastic parts at 39 years old. I am trying to find a regular grommet that I can cut and then superglue together once it is over the harness. Failing that I will use a plastic grommet and seal it with marine sealant and try that. After removing the passenger fender I now need 2 grommets!
whysotamale
May 31, 2023 07:42 AM
westfalia
Jan 8, 2022 05:38 PM
tha_joker
Nov 6, 2011 08:23 AM
surfmobile
Oct 19, 2006 04:56 AM
