Yet ANOTHER rim size question thread
Yet ANOTHER wheel size question thread
Been searching the forums and reading numerous threads, but still got doubts on this. I would appreciate if someone could help me out:
I'm currently running 31x10.5 BFG M/T on my '94 4wd pickup:
I have no idea on the specs of the current wheels (just bought the truck a few months ago), and I want to swap them for some steel wheels. I'm happy with the current setup (just the amount of extension beyond fender wells illustrated on the pic above), so I want to keep it as is. Truck is completely stock, no lift or other mods. Also, I will be sticking to this tire size in the future (31x10.5).
I'm looking into a set of steel Procomp 97 Series 15x8 with a 6 on 5.5 bolt pattern and 3.75 backspacing. Would these be the specs to go for?
Thanks for any feedback!
Instead of steelies, some nice TRD rims would also look great. But $$$
I like them too, but the reason is I had to get one of them repaired (had a crack and was leaking air. Actually it still leaks, but much much less), and I have no idea on what abuse those wheels were subjected to by previous owners. Considering one of the wheels needed repair, I don't trust much the other ones.
I think steel wheels may be more durable, can be more easily and confidently repaired, and help give the truck the simple, "agricultural" look I want it to have. I live in Mexico, I'm a biologist, and this truck I'll be using it for work in the Sierra Madre Oriental mountains, and I want a truck which "blends in" more easily with the local farmers' worn out old Chevy and Ford Trucks.
Back in the days when alloy wheels were "new," I was told that one very big advantage is that they are rounder. Steel wheels are (were?) stamped, but alloy wheels were machined. At one point, tire installers would use a machine that actually scrapped tiny bits of rubber off a tire mounted to a steel wheel to make the tire rounder. Maybe it was marketing gim-crack, but wadda I know.
Of course, roundness is more important at higher (highway) speeds, and you may not care as much in the mountains. I suppose a steel wheel might bend when an alloy wheel would crack, but in either case they wouldn't hold air.
That may well still be true (alloy wheels being rounder) , must depend on manufacturing quality of steel wheels. Alas, my budget I must balance between many components that need (some urgently, some preventative) replacement on my truck, so I'm definitely leaning towards the lower cost of steel wheels.
DrummerDaveB
7
06-18-2004 09:38 AM
