Anyone know what wheels these are?
Old 03-18-2018, 03:38 PM
littleecker's Avatar
Title says it all. Looking for dust caps that will fit.
Old 03-18-2018, 04:02 PM
scope103's Avatar
As in, 15x7 JJ, Type C ? https://parts.lakelandtoyota.com/sho...rimLevel=18292
The ones I have are clear-coated aluminum. Yours are the first painted ones I've seen (well, clear coat is paint, isn't it?)
I have the Type 9 "Wheel Hub Ornament." https://parts.lakelandtoyota.com/sho...rimLevel=18292 I was able to get a close match (different "Type") from a salvage yard.
Old 03-19-2018, 03:00 AM
wallytoo's Avatar
appears to be the stock alloy wheel from 2nd gen 4runners (1990-1995). the 1st gen 4runner (1984-1989) had a stock alloy wheel that looked similar, but had a different offset. the center caps do not interchange between wheelsets. get caps from a 2nd gen.
Old 03-19-2018, 06:09 AM
SomedayJ's Avatar
I think this is what you're looking for:
http://www.hubcaps.org/options/toyc102options.html
Old 03-19-2018, 03:28 PM
Fossilized
dropzone's Avatar
1st year was 86
Old 03-19-2018, 03:51 PM
wallytoo's Avatar
Originally Posted by dropzone
1st year was 86
right, with the intro of IFS.
Old 03-23-2018, 06:42 AM
881stgen's Avatar
Seriously??? I just bought a set of alloys on craigslist from a 91. I have manual hubs so I need to replace the front caps with the open caps which are much more rare probably because there weren't many 2nd gens with manual hubs.
Old 03-23-2018, 07:12 AM
SomedayJ's Avatar
Don't quote me on this, but I think you can take a close one and remove the center of it to fit the hub. I remember somebody did it using small drills and those porting kits:
https://www.ccspecialtytoolstore.com...-p/dppak50.htm
but I can't find the thread.
Old 03-23-2018, 07:35 AM
881stgen's Avatar
That's my next step. Even if I can find the caps I don't want to spend more on them than I spent on the wheels.
They want $100 for a pair on Lakeland Toyota. Holy hell!
Old 03-23-2018, 08:45 PM
22BrokeBoyRE's Avatar
I found some hubcaps from a local pick and pull. I cut out the center with a hole saw from harbor freight (Item #69073), which can usually be bought for about $10 with a coupon.
Old 03-23-2018, 10:07 PM
Co_94_PU's Avatar
What, caps for manual hubs?
Old 03-24-2018, 04:32 PM
blueknob's Avatar
Just take the factory caps and drill them out with a the hole saw, I think it was 3 1/2 "
Old 03-24-2018, 04:35 PM
blueknob's Avatar
if you want black lug nuts, here ya go https://www.ebay.com/itm/24-Black-Ma...19.m1438.l2649
Old 03-24-2018, 04:49 PM
Another view with Aisin hubs.
Old 03-24-2018, 06:47 PM
881stgen's Avatar
Awesome! I actually found one at a junk yard for a couple bucks which was perfect because I only had 3 anyways. Looking at the one I bought it's gonna be no problem to just cut the opening out.
On a side note I was going back and forth on keeping the wheels own color or powedercoating them black. After seeing multiple different ones in black on this thread I now have no choice. I'm going to make them black somehow. How did you guys do it? Powder coat? Or just paint? I don't want them to chip and peel. And actually I was going to leave those spaces aluminum colored just like these. Looks sick!
Old 03-24-2018, 07:50 PM
I used VHT Wheel Paint SP187 gloss black paint can. It has held up for 2 years, besides some minor chipping along the edge and around the lug holes. I think that was my own fault for not painting properly. My squares are not even lined straight so that just shows how much I prepped. Personally, I think I prefer the oem alloy look, which I may go back to.
Old 03-25-2018, 07:29 AM
SomedayJ's Avatar
Are the manual Warn hubs taller than the Aisin ones? If I remember correctly, the DIY open center cap looked more like this:
Did you make the hole in that one?
Old 03-25-2018, 08:35 AM
blueknob's Avatar
the warns must be taller, never had a set of aisins so i wasn't aware
iamsuperbleeder
10-19-2012 07:31 AM
El Gringo
08-07-2011 04:40 PM
Ilovemountains
All Other Toyota Swaps
01-08-2010 01:28 PM
Murakami
07-28-2009 04:16 PM
GreenRunner
14
10-29-2004 09:55 AM
Quick Reply: Anyone know what wheels these are?
