battery light and brake light on
Old 01-03-2008, 04:40 PM
spanish-road's Avatar
1991 toyota 4x4 22re
Well my brake light is on and battery light is on at the same time, also the voltage is low. I checked the fuses and this has been going on for a few weeks.
Old 01-03-2008, 04:41 PM
linuxrunner's Avatar
check the alternator
Old 01-03-2008, 04:47 PM
Banned fruitloop
4runnerchevy's Avatar
Alt.
Agreed. That is your Toyota truck telling you your alternator (or wiring to it) is dead. Check that FIRST!
Old 01-03-2008, 04:50 PM
VoxMan's Avatar
This happened to me on my '95 runner and it turned out i hadn't tightened the alternator bolt so the belt was slipping half the time. Re-tensioned the belt and cranked down on the bolt and no more problems.
Old 01-03-2008, 05:44 PM
Well I checked it and its on its last leg cause I removed the battery and put in a spare that was new and it did the same thing, also I removed the battery while it was running and it died when it had high beams, brakes, flashers, wipers all on.
Old 01-03-2008, 05:54 PM
Banned fruitloop
Battery
Truthfully IT IS your Toyota truck, telling you it IS your alternator. Take it out, or not, and test it ! Just my guess !
Old 01-03-2008, 06:03 PM
williemon's Avatar
Had same issues on my 90 runner. It has a volt meter as well and showed alt was not putting out, but then a few miles down the road, it started working fine again. Been doing this every day for the past month. I ordered a brush and holder asy. for the alternator from the toyota place and just installed it. The old one was worn out compared to the new. I have not tested it yet because my intake busted all up taking it out. 30 min job has now turned into an intake mod job.
Old 01-03-2008, 08:06 PM
toytech76's Avatar
Its your alternator. While its running tap on it with something and it might start charging again. You can just replace the internal brushes to fix the problem. DON'T BUY A NEW ALT. ESPECIALLY FROM KRAGEN
Old 01-07-2008, 11:15 AM
4Crawler's Avatar
Inexpensive to repair:
http://www.4x4wire.com/toyota/mainte...nator_brushes/
And X2 on repair vs. replace.
Old 01-07-2008, 11:44 AM
toytech76's Avatar
I am gonna be starting to sell brushes for alts. $12 + 6 to ship
Old 01-07-2008, 01:41 PM
Noahrob's Avatar
This is a good thread! What about upgrading at the same time? I know that Mr. Alternator and a rewound alternator are not a good way to go, but Alterstart in Texas is selling a 160amp (75amps at idle) with a two year warranty and print out of the bench test for $229. Thoughts?
Old 02-15-2010, 06:35 PM
83toy4x4509's Avatar
Help
Help guys I took alternator out had tested it tested good i put new belts on I tigthen everything good Double check twice and still have problem of brake and battary light on but u rev motor over 4000 rpm lights go out turn off start up again they come back on and do it all over again so can anyone help me out it's driving me crazy any idea would help alot
Old 02-16-2010, 08:06 PM
Any ideas anyone
Old 02-17-2010, 04:34 AM
waskillywabbit's Avatar
Alternator is bad or something else is wrong with your charging system.
Ncttora.com/fsm
Old 02-17-2010, 04:43 AM
Had it tested could it still be the altenator thow I have no idea what else it could be thow grrrr
Old 02-18-2010, 05:17 PM
I got a new one and still doing same thing grrrr
Old 02-23-2010, 12:11 AM
YoterMoter's Avatar
Hey buddy, If you replaced your alt with a new one and it is still doing it then it sounds like you need to check your connector that plugs into the back of the alt, Mine did the same thing and i wrote it off as being the alternator, after spending $130 on a new one only to find out it was still there i realized that 1 of the wires that goes into the plug that plugs into the alt had pulled out of the plastic plug itself. It was an easy fix but it happened again later on so i ended up putting the wire back in the plug again but this time i used a few zip ties around the wires going into the plug to keep the wires from getting jar'd around during normal engine operation etc...it hasnt let me down yet. So i suggest trying that, examine the plug real good make sure your connections are not packed with corrosion as well. Hope that helps bud...
Old 02-23-2010, 04:48 AM
Thanks I'm going to try that I'm taking the napa crap one out and making them give me a new one and I'm checking wire everything again so hopefull I can find it wish me luck
Old 04-14-2012, 05:55 PM
vanduzerwilliam's Avatar
I had the same problem with mine, sprayed the plug with electronic cleaner and hit it with a wrench a couple times, and volts came up and works fine now
Old 04-14-2012, 07:33 PM
James Woods's Avatar
Wrenches are for bolts and nuts, hammers are for hitting stuff.
Quick Reply: battery light and brake light on
