Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Todd's new bed
Old Oct 4, 2011 | 05:24 PM
slacker's Avatar
toyotafiberglass - Todd's new bed and windshield area repair
Todd booked his truck in for a box replacement ..
we got right to work !!
got the box removed .. and YIKES!! it's a sad day
contacted Todd , and sent him some pics of the rust
Old Oct 5, 2011 | 06:05 PM
slacker's Avatar
so with the "go ahead" from the owner ..
some progress today
I started the day with cutting some "fish plates"
also .. got the support tube removed
fit and ready to weld
and some melted metal
also the new support tube
all wire wheeled , metal etched , washed .. and drying overnight for the POR tomorrow ..
Old Oct 5, 2011 | 06:13 PM
87 Deathtrap's Avatar
That truck's a great candidate for the Slacker treatment. Subscribed for another awesome build!
Old Oct 6, 2011 | 04:33 PM
slacker's Avatar
so all dried this morning , started the POR 15 treatment ..
also the inside .. as best I can anyway ..
and after done with the spraying , I go around with a brush , to "touch up" the missed spots .
and while the frame is curing .. I started on the fuel tank pickup ..
Toyota dosnt include new screws .. but I have em ..
A little Never sieze ..
with the frame cured enough to start installing everything else ..
I got it back together , and ready for the box tomorrow
Old Oct 7, 2011 | 05:00 PM
slacker's Avatar
and now with the box installed .. ALL done !!
Old Oct 10, 2011 | 05:04 AM
southernZ's Avatar
Man what a difference......if I don't go the flatbed route on my '80, ill be contacting you sir!
Old Oct 11, 2011 | 04:01 PM
slacker's Avatar
thanks .. we'll be here if ya need us ..
we are VERY busy though .. so be prepared for a wait ..
Old Oct 18, 2011 | 08:48 AM
1986yota4x4's Avatar
how much does a bed like that cost?
Old Oct 18, 2011 | 04:42 PM
slacker's Avatar
long bed starts at (please see web site for pricing) (double wall construction)
Old Dec 2, 2015 | 04:28 PM
slacker's Avatar
Todd is back ... with a serious windshield leak . and asked me to fix it ..
so here we go
and got the windshield out .... YIKES !
called Todd to confirm , and he loves his truck , so I am proceeding
Old Dec 4, 2015 | 04:06 PM
slacker's Avatar
building the pieces to fit
Old Dec 10, 2015 | 09:59 AM
kawazx636's Avatar
Looks like some shrinking and stretching fun!!
Old Dec 10, 2015 | 03:56 PM
slacker's Avatar
yeah , it's ugly in there .. just about done building the new pieces , hope to get cutting tomorrow
also got a new RUBBER weatherstrip coming ... no more "gluing" and cutting for this windshield !
Old Dec 11, 2015 | 05:39 PM
slacker's Avatar
started cutting and welding today ..
started on the drivers side vertical pillar , and worked my way up
when cutting the uppers , you need to be sure not to cut to deep , as there are corner roof supports in there ... they are usually ok , as they are underneath the corners . also , you need to seal the bare metal .. I use zinc "weld threw primer" .. I will also seal everything from the inside as best I can when I'm done .
Tacking the new piece in place , and working with the "heat" very slowly
and moving in sections .. as with the corners , the roof header also has a support , so be sure not to cut it ...
so far so good
Old Dec 17, 2015 | 04:08 PM
slacker's Avatar
so basically done for the moment ... I waiting for a delivery I have coming from Japan with the OE rubber windshield weatherstrip . along the bottom of the windshield opening , the dash bolts there , and there is a flange there , I assume to "hide" the glue area , and urethane ooze on the bottom . pretty sure I will need to cut this off for the thickness of the new weatherstrip to fit , but I just want to make sure
Old Dec 23, 2015 | 05:30 PM
slacker's Avatar
so the new weather strip showed up today ...
and as I suspected , for BEST fit , the flange on the dash should be cut .. so this was how I proceeded
easy to do with the windshield out
primed
and painted while the windshield is out , curing overnight .
Old Jan 1, 2016 | 04:59 PM
arlindsay1992's Avatar
Any more info on the rubber weather stripping? Is this something the Japanese trucks got that ours didn't? What benefit does it have over the US trucks.
Old Jan 8, 2016 | 04:53 PM
slacker's Avatar
back from holidays ... so will be continuing on this build on MONDAY the 11th
Old Jan 12, 2016 | 04:11 PM
slacker's Avatar
so got the welding all done ...
a "skiff" of bondo , and some epoxy to cure overnight
Windshield is ordered , and will be here tomorrow .... But , we are replacing ALL of our light fixtures tomorrow , so not sure if i'll get the shield installed tomorrow ..
Old Jan 15, 2016 | 04:22 PM
slacker's Avatar
so ready to install the windshield
new weatherstrip installed , here we go
fit excellent .. VERY happy .
cowl and inner trim fit PERFECT !!
we now have a quantity coming into the shop for retail sale , so if your interested , please email me
