Spybot S&D Bad Check Sum
Old 07-27-2004, 08:23 AM
Glenn's Avatar
Hi
Every time I attempt to download the updates for Spybot Search & Destroy, it somes back with !!! bad check sum !!
What does it mean?
Any fix?
Thanx!
Old 07-27-2004, 08:46 AM
Morr's Avatar
Originally Posted by Glenn
Hi
What does it mean?
Any fix?
Thanx!
No idea what it means, have got it before on corrupted zip files, I suspect this file is similarly corrupted.
BTW you're not alone, I had the same problem yesterday when trying to update spybot too, tried it on two different machines, but no go!
Old 08-02-2004, 06:41 PM
amusement's Avatar
A "bad check sum" means the file was corrupt either in transit or at the source.
Check sum is a method by checking the amount of bytes in a file. In the bytes don't match the expected value (check sum) then the file is corrupt.
Help it helps ... and it isn't your computer ... could be the download (network) or source file.
Cheers!
Eggslinger
06-08-2019 03:32 PM
raptor510
02-17-2017 07:11 AM
PlayAwhile
07-20-2015 11:36 AM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Spybot S&D Bad Check Sum
