POLL: How long has your computer been on?
Old Apr 2, 2005 | 11:07 AM
4RUNR's Avatar
Guest
Well, technically the hard drive. This is what the thread is about.
As some of you know, virtually all hard drives manufactured since around 1996 support S.M.A.R.T, which stands for "Self Monitoring And Reporting Technology". It is like an odometer on a vehicle, just mode advanced.
Two of the many things that S.M.A.R.T keeps track of is how many times the hard drive has been cycled, and how many hours it has been on, since birth.
There are many utilities available for retrieving S.M.A.R.T data, but here is one only 44kB in size and requiring no installation. Just run "DiskCheckup.exe".
Homepage: www.passmark.com (screenshot attached)
Direct download: http://www.benchmarkhq.ru/cgi-bin/mclick.cgi?44
So let's make a small knowledge base, with general satisfaction comments, based on what hard drives you own/owned. I'll start with 5 drives, in chronological order that were in my desktop computer:
Model : IBM-DTTA-371440
Capacity : 13.5GB
Start/Stop Count 2281
Power-On Time Count 19193 (800 days)
Power Cycle Count 1319
Comments: IBM Desktar, noisy bearings.
Model : ST320011A
Capacity : 19.0GB
Power-On Time Count 17298 (721 days)
Power Cycle Count 1108
Comments: Seagate Barracuda IV, perfect.
Model : ST330011A
Capacity : 28.5GB
Power-On Time Count 11199 (467 days)
Power Cycle Count 910
Model : WDC WD400EB-11CPF0
Capacity : 37.3GB
Start/Stop Count 323
Power-On Time Count 4584 (191 days)
Power Cycle Count 214
Commens: Western Digital Caviar, VERY noisy bearings.
Model : Maxtor 6Y060P0
Serial Number : Y2MW2LME
Capacity : 57.3GB
Start/Stop Count 113
Power-On Time Count 29565 (1231 days)
Power Cycle Count 127
Comments: Perfect. Still in use.
Attached Thumbnails POLL: How long has your computer been on?-smart.gif
Old Apr 2, 2005 | 11:47 AM
Corey's Avatar
Co-Founder/Administrator
Seagate Baracuda 80 GB 7200 RPM:
Drive 0 SMART enabled
IDE REGISTERS:
Features: 0x0 Sector Count: 0x1 Sector Number: 0x1
Cylinder Low: 0x0 Cylinder High: 0x0 Drive Head: 0xA0
Command: 0xEC
DRIVE INFORMATION:
Serial Number: 5JV05KM1
FirmWare Rev: 3.06
Model Number: ST380011A
Cylinders: 16383 Heads: 16 Sectors per track: 63
Cur Cyls: 16383 Cur Heads: 16 Cur Sectors/Track: 63
Bytes per track: NA Bytes per sector: NA
Gen Config: 3162 Buffer Type: 0 Buffer Size: 4096
Vendor Unique: 0 0 0 More Vendor Unique: 0x8010
ECC Size: 4 Double Word IO: 0 Capabilities: 12032
PIO Timing: 512 DMA Timing: 512 BS: 7
Current Sector Capacity: 16514064 Total Addressable Sectors: 156301488
Mult. Sector Stuff: 272 Single Word DMA: 0 Multi Word DMA: 7
SMART ATTRIBUTES:
ID Description Raw Value Status Value Worst Threshold
1 Raw Read Error Rate 88003543 OK 65 63 6
3 Spin Up Time 0ms OK 99 98 0
4 Start/Stop Count 46 OK 100 100 20
5 Reallocated Sector Count 0 OK 100 100 36
7 Seek Error Rate 349662995 OK 85 60 30
9 Power On Time 5706 (238 days) OK 94 94 0
A Spin Retry Count 0 OK 100 100 97
C Power Cycle Count 1482 OK 99 99 20
C2 Temperature 32 C OK 32 46 0
C3 (Unknown attribute) 88003543 OK 65 63 0
C5 Current Pending Sector Count 0 OK 100 100 0
C6 Offline Scan Incorrect. Sector Count 0 OK 100 100 0
C7 Ultra ATA CRC Error Count 1 OK 200 199 0
C8 Write Error Count 0 OK 100 253 0
CA Direct Address Mark Error Rate 0 OK 100 253 0
Old Apr 2, 2005 | 12:50 PM
data's Avatar
Senior Member
Model Number: Maxtor 92049U3
9 Power On Time 1647303
C Power Cycle Count 1037
Model Number: Maxtor 5T030H3
9 Power On Time 28359
C Power Cycle Count 570
Model Number: Maxtor 4W100H6
9 Power On Time 9458
C Power Cycle Count 424
Old Apr 2, 2005 | 01:09 PM
CynicX's Avatar
9 Power On Time 36432
C Power Cycle Count 132
Old Apr 2, 2005 | 04:14 PM
photoleif's Avatar
Model: IBM-DTLA-307045
Capacity: 40.0GB
Power On Time: 10727 (447 days)
Power Cycle Count: 2067
Temperature: 32 C
Comments: IBM Deskstar; very good
Model Number: WDC WD1600JB-53EVA0
Capacity: 160.0GB
Power On Time: 4753 (198 days)
Power Cycle Count: 705
Temperature: 29 C
Comments: Western Digital; excellent
Old Apr 2, 2005 | 06:45 PM
pinnacle's Avatar
Model Number: WDC WD800JB-00ETA0
Capacity: 80.0 GB
Power On Time: 728 (30 days)
Power Cycle Count: 498
Temperature: 27 C
Model Number: ST340014A
Capacity: 40.0 GB
Power On Time: 84 (3.5 days)
Power Cycle Count: 189
Temperature: 30 C
Old Apr 10, 2005 | 08:03 AM
Sherpa's Avatar
Dell Notebook
Power on time 1000 hours
Old Apr 10, 2005 | 11:57 AM
dibble9012's Avatar
Maxtor hard drive in a dell dimension 8250.
IDE REGISTERS:
Command: 0xEC
DRIVE INFORMATION:
Serial Number: D27MWDGE
FirmWare Rev: DAK019K0
Model Number: Maxtor 4D040H2
Cylinders: 16383
Heads: 16
Cur Cyls: 16383
Cur Heads: 16
Bytes per track: NA
Gen Config: 64
Buffer Type: 3
Buffer Size: 4096
ECC Size: 57 Double Word IO: 0 Capabilities: 12032
PIO Timing: 512 DMA Timing: 0 BS: 7
Current Sector Capacity: 16514064 Total Addressable Sectors: 80043264
SMART ATTRIBUTES:
3 Spin Up Time 4105ms OK 235 234 63
4 Start/Stop Count 1005 OK 253 253 0
5 Reallocated Sector Count 0 OK 253 253 63
6 Read Channel Margin 0 OK 253 253 100
7 Seek Error Rate 0 OK 253 252 0
8 Seek Time Performance 60399 OK 244 233 187
9 Power On Time 37432 OK 223 223 0
A Spin Retry Count 0 OK 253 252 157
B Calibration Retry Count 0 OK 253 252 223
C Power Cycle Count 750 OK 252 252 0
C0 Power off Retract Count 0 OK 253 253 0
C1 Load/Unload Cycle Count 0 OK 253 253 0
C2 Temperature 0 C OK 253 253 0
C3 (Unknown attribute) 5 OK 253 252 0
C4 Reallocation Event Count 0 OK 253 253 0
C5 Current Pending Sector Count 0 OK 253 253 0
C6 Offline Scan Incorrect. Sector Count 0 OK 253 253 0
C7 Ultra ATA CRC Error Count 0 OK 199 199 0
C8 Write Error Count 0 OK 253 252 0
C9 Off Track Errors 3 OK 253 252 0
CA Direct Address Mark Error Rate 0 OK 253 252 0
CB Error Correction Code Errors 0 OK 253 252 180
CC Raw Read Error Rate 0 OK 253 252 0
CD Thermal Asperity Rate 0 OK 253 252 0
CF Spin High Current 0 OK 253 252 0
D0 Spin Buzz 0 OK 253 252 0
D1 Off Line Seek Performance 0 OK 253 253 0
63 (Unknown attribute) 0 OK 253 253 0
64 (Unknown attribute) 0 OK 253 253 0
65 (Unknown attribute) 0 OK 253 253 0
Old Apr 10, 2005 | 11:59 AM
dibble9012's Avatar
thats a long thread, lol, i didnt feel like deleting all the extra numbers, well uptime is 37432 hours, stop/start 1005
Old Apr 15, 2005 | 11:21 AM
984runner's Avatar
Is that power on time in Hours? If it is, it translates to 188 years.
Old Apr 15, 2005 | 11:28 AM
984runner's Avatar
When was the last time you ran a defrag on your drive? Might want to look into your high rate of read and seek error rates.
Old Apr 15, 2005 | 12:53 PM
joez's Avatar
9 Power On Time..........:604962
C Power Cycle Count.....:453
Old Apr 15, 2005 | 01:13 PM
4RUNR's Avatar
Guest
That's the bad thing. There is no real standardization for S.M.A.R.T. data. Some drives store power on time in hours, some in seconds. Great idea to counteract the least reliable component in a computer, the hard drive, bad idea not to standardize.
Old Apr 16, 2005 | 07:20 AM
data's Avatar
Senior Member
beats me...LOL! I just copied and pasted what it said
Old Apr 16, 2005 | 09:18 AM
jimbo74's Avatar
its been on long enough that my internal battery died.....
88sasturbotoy
Jan 30, 2026 01:57 PM
jashoeuh
Nov 18, 2024 08:08 AM
foampile
Dec 18, 2022 01:29 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
