Linksys WRE54G Range Expander and Linksys WPS54G Print Server - Config Issues
Old Jan 16, 2005 | 03:44 PM
Cebby's Avatar
I'm having issues setting these pieces up. I can't see them from my network?? Using either the setup wizard or trying to see the units via IP addresses - they just aren't showing up.
Here's what I have now:
BEFSR41 DSL Router/Switch (version 2)
WAP54G Wireless G Access Point
Trying to configure the network to see:
WRE54G Wireless G Range Expander
WPS54G Wireless G Print Server
I have been monkeying with this thing for two days now. Got the Access Point running pretty easily, but this other stuff is making me batty.
Here's what I've tried:
Leaving all defaults:
SSID = linksys
Channel 6
Security disabled
DHCP enabled
Tried changing:
The SSID
WEP 64 bit
Here's what is on my network:
Two desktops (wired), one laptop (wireless), one dedicated printer (I want the Print Server for this), and one networked printer (wireless).
If I can get this stuff running right, I plan to add one more desktop (wireless)
What should I be looking for? Is there a setting on my router or the wireless that is not letting this stuff be "seen"?
Thanks in advance!
Old Jan 16, 2005 | 03:48 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Have you tried:
-turning off encryption?
-setting static IP's for the range extander and print server?
-changing the channel to a different one? (I use 11 since there's another network near me on 6 and they conflict.)
I hope this helps.
Old Jan 16, 2005 | 03:53 PM
Cebby's Avatar
It should be noted that when I had everything at the default settings, I got the range expander to "work". By work, I mean i was able to get into it via a browser. The problem was it made my wireless laptop absolutely crawl on the internet. I had it about a foot from my computer at the time. As soon as I changed from the defaults, it wouldn't see the wireless network.
Old Jan 16, 2005 | 03:56 PM
Cebby's Avatar
I have turned off the security, but I think it only helped the range expander "work" that one time.
I'll try the alternate channel - I didn't see in my laptop where I choose a different channel though
I'll try setting the static IP's for the two items using the default values. Not sure where to do this, but I'll go poke around.
Old Jan 16, 2005 | 08:43 PM
Cebby's Avatar
OK - I got the print server working and even got the range expander to be "seen" again (through the setup CD this time!). After a short time though, I lost connectivity to the access point. I unplug the range expander from the wall and I regained access. This time I had it a good distance from my laptop and the access point. It is odd to say the least.
RatOmeter
Oct 22, 2015 03:17 PM
altydog
Jul 28, 2015 10:20 AM
Athansinis
Jul 27, 2015 08:38 AM
1996Taco
Jul 20, 2015 12:02 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
