GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Trying to Trouble Shoot CB Issue???
Old Sep 7, 2008 | 11:31 AM
sbikes's Avatar
A few months ago I installed the Cobra 75 WX St in my 07 taco. It worked great up to last week, now it wont even turn on. I've spend my moring checking all the connections and everything looks good. It's connected to my battery so it SHOULD work when the car's on or off, but neither works.
Just wanted to see if anyone had any ideas, or has dealt with this in the past. Thanks
Old Sep 7, 2008 | 11:47 AM
blackspyder's Avatar
1)replace the in line fuse with a 5 amp.
2)run a second ground back to the battery
if neither of those work than take it to your loacl CB shop and have them check it out
Old Sep 7, 2008 | 11:54 AM
Hayes's Avatar
I would check the fuse, but I wouldn't put a bigger fuse in. That could make something in the CB short before the fuse, negating the whole point of the fuse. Anyways, check the fuse and then trace all the wires.
Old Sep 7, 2008 | 11:56 AM
sbikes's Avatar
I should have mentioned...I did check the fuse and it looks fine
Old Sep 7, 2008 | 12:08 PM
grant526's Avatar
Did you check to see that there is power the the hot side of the fuse? You can do this with a test light or a multimeter.
Did your unit get pulled on recently? Maybe a connection in either end was compromised by getting over extended?
I have the same unit and Love it!
Good Luck!
Old Sep 8, 2008 | 11:29 AM
sbikes's Avatar
That's a good though on the test light.
but nothing has been pulled or over streched since its been installed.
I'm going to give cobra a call this week since its still under warrenty.
Thanks for the input
Old Sep 11, 2008 | 05:22 PM
schmooot's Avatar
if you have power going into the connector in the back (and providing a solid ground as well) then your problem lies inside the radio
Old Sep 11, 2008 | 05:31 PM
jsn_stockard's Avatar
Double check the ground, it needs as good of a connection as the hot
Old Sep 11, 2008 | 05:33 PM
Also check your coax, If it has a raw spot it can fry a cb. Have you ever done a SWR check before it went out?
Old Sep 16, 2008 | 10:19 PM
CashMoney's Avatar
yep we've had cb's at work fry on the diesel trucks when an antenna gets broke and SWR's get high. Another thing i've had happen is if they won't talk or recieve the microphone could be bad.
mskalmus
May 28, 2017 07:51 AM
defrag4
Jul 31, 2015 10:50 AM
kirkrunner
Jul 27, 2015 07:59 PM
sabine
Jul 18, 2015 03:59 PM
Poncho0206
Jul 10, 2015 06:21 PM
