GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Question: cb antenna on yakima rack/canopy rail
Old Mar 12, 2006 | 06:52 AM
sasquatch's Avatar
I'm curious if I can mount my firestick II on the rails of my yakima rack system and get it to work as well as ...say, mounted on the fender ?
I have extra perches for the yakima rail system and thought it'd be a good/high location to have it.
I think the only issue in doing it that way, is the ground. I plan on using stainless wire loom and stainless wire connectors.
As far as the grounding points, here's what I planned to do.
Grounding antenna to frame...
Grounding the hood to the cab...
Cab to the bed...
Bed to the frame ..and exhaust to the frame.
Whats your thoughts???
Old Mar 12, 2006 | 10:41 AM
Bob_98SR5's Avatar
firestik sells non-ground plane antennas. this would be better suited to your mounting option. check out jacksonpt's website
bob
Old Mar 12, 2006 | 12:52 PM
ecchamberlin's Avatar
I know Phalanx is running his on the Yak Load Warrior he has and his set up works very well.
May give up some distance overall but I guess it comes down to what you need it to be able to do. I only use mine for trail runs and we are all in a pretty tight group so I don't need much range.
Old Mar 13, 2006 | 10:26 PM
deathrunner's Avatar
just run a huge ground (10 gauge) from the antenna base to the frame. That will do. That should be an ideal location.
Old Mar 14, 2006 | 06:07 PM
sasquatch's Avatar
I appreciate the replies......thanks !!
I decided to go with the standard fender mound.
I'm having a bit of problem with noise from the heater/fan. I was sitting in my truck at lunch today, listening to the cb. There were a lot of other cars driving by. Seemed I was getting feedback from them coming through the radio. I don't understand this.
I have the dang thing grounded real good.....I thought.
How the heck can I resolve all the feedback ??
Old Mar 15, 2006 | 10:54 AM
fourwd1's Avatar
Cab to the bed...
First off, the antenna requires a groundplane, not an electrical ground.
A groundplane is a flat surface of metal on whick the antenna is mounted. This groundplane acts as the second half of the antenna. the bigger the surface area of metal the better, that's why the roof is the best place to mount an antenna (plus the height factor).
If your Yakima rack is grounded to the roof via it's mounting, it's possible that the roof still might act as a groundplane and your antenna might work decently, especially if you can mount the antenna on the rack at a point near the center of the roof.
Or just get a good mag mount antenna like the Wilson or K40 and stick it on the roof.
As far as the rest of your grounding questions, the battery neg terminal is grounded to both the frame and the cab. You can add a ground from bed to frame, hood to cab is OK but hood to frame is better. Don't go from cab to bed. In other words, reference everything to the frame. Screw the exhaust.
Old Mar 16, 2006 | 04:34 PM
sasquatch's Avatar
Thanks for the reply fourwd1
I'll make the grounds go from antenna/hood to frame and see what happens.
kawazx636
Oct 6, 2021 03:03 PM
moparbay
Oct 6, 2015 09:24 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
Ilovemountains
Sep 15, 2015 04:17 AM
