GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Let's see those CB Radios
Old Apr 19, 2010 | 06:06 PM
B4Runner's Avatar
I just won my Cobra 25 LTD Classic with side mounting mic on eBay for exactly $50 shipped. It's going ride under my HU. I'm just excited to get idea of what it will look like. So how about some pix of those CB Radios out there?
Old Apr 19, 2010 | 06:21 PM
Elton's Avatar
here's my cobra 29 wx nw st my friend gave me also the one you got may not work under the hu
Old Apr 19, 2010 | 06:24 PM
B4Runner's Avatar
Unless my tape measure is off, it will fit.
Old Apr 19, 2010 | 06:38 PM
runneroffroad's Avatar
did you measure the depth? when i tryed to put my cobra 29 under mine in was to shallow of a hole and would stick out to far for the top gears shifting.
EDIT: i cant remermber if the 25 is shorter then the 29
Old Apr 19, 2010 | 06:48 PM
crawlerjunkie's Avatar
here is my dx 959, it was getting to hot on the roof so i moved it. Its tight and took some adjusting with a hammer but its good now
https://www.yotatech.com/attachment....6&d=1271051106
Attached Thumbnails Let's see those CB Radios-photo0290.jpg   Let's see those CB Radios-photo0289.jpg
Old Apr 19, 2010 | 06:59 PM
boxer.fan's Avatar
Here is mine. I cut the back out of the pocket so that it would fit.
Old Apr 19, 2010 | 07:04 PM
chrishf12's Avatar
Here is mine
Old Apr 19, 2010 | 10:13 PM
dark_fairytales's Avatar
I know you have my photobucket saved as one of your favorits but here are the pics your asking for.
the cb will stick out some and the handset connection comes vary close to the shifter. remember i have a body lift and when i to the drive train lift it my not work. so far it a good spot and if i run into problems i could always tweak the shifter.
Old Apr 20, 2010 | 06:07 AM
B4Runner's Avatar
Researched the dimmentions in comparison:
25: 8.5 x 6.25 x 2.125
29: 8.625 x 7.25 x 2.25
Originally Posted by chrishf12
Here is mine
Looks great right there.
I hope I can get away with the shifter not being away. My radio also has the side-mounting mic, so I won't have to worry about that part getting in the way.
Old Apr 20, 2010 | 09:33 AM
Corey's Avatar
Co-Founder/Administrator
Cobra 29 NightWatch bumped to 25 watts.
Below the glovebox.
Old Apr 20, 2010 | 01:20 PM
25 is nice but 40 pushing
Old Jan 12, 2012 | 08:06 PM
Teuf's Avatar
I know this is quite a jump, I'm bored,,,,,,,,
Old Jan 12, 2012 | 08:13 PM
MKtaco_98's Avatar
Its all good thread is a sticky.
old pic but its all I got
Old Jan 12, 2012 | 08:24 PM
Teuf's Avatar
MK does your cobra reset to channel 1 when you shut off n restart?
Thanks..
Old Jan 12, 2012 | 08:30 PM
MKtaco_98's Avatar
Thanks..
Nope stays on the channel I left it on, how did you wire yours up?
Old Jan 13, 2012 | 05:12 AM
habanero's Avatar
Old Jan 13, 2012 | 08:38 AM
Teuf's Avatar
OK I'll recheck what point I wired it up to. I guess that makes a difference.
Old Jan 13, 2012 | 08:46 AM
MKtaco_98's Avatar
haha should of asked how is it getting power, I wired mine straight to the battery so I could use it without the keys in the ignition
Old Jan 13, 2012 | 08:50 AM
Teuf's Avatar
Well I plumed into the drivers fuse box, cig lighter fuse? I'll reroute it to a permanent power point.
Old Jan 13, 2012 | 09:24 AM
irab88's Avatar
my first setup:
current setup:
