GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
laptop mounts
Old Oct 6, 2005 | 05:34 PM
nermalgod's Avatar
laptop mount (updated with install pics)
Not being able to fab anything custom, has anyone found a strong laptop mount that doesn't infringe on passenger comfort and adjusts easily?
Last edited by nermalgod; Oct 23, 2005 at 04:50 PM. Reason: resolution for my inquiery
Old Oct 6, 2005 | 10:28 PM
Noliwan's Avatar
Here ya go...
http://www.gpscity.com/toyota/all-mo...icle-mount.htm
Old Oct 7, 2005 | 05:39 AM
shazaam's Avatar
I don't know how stable it is ... but there is a guy selling them on Ebay for around $40. I just can't justify spending $200+ on a stand.
Old Oct 7, 2005 | 06:06 AM
Racer944's Avatar
http://cgi.ebay.com/LapTop-Mount-Off...QQcmdZViewItem
One guy built this or had it built here on yotatech, and someone now sells it on ebay. Not a bad price and says that it fits things perfectly.
Old Oct 23, 2005 | 05:02 PM
nermalgod's Avatar
Put together this stand from a bunch of RAM parts and the wood shelf I created for cabinet I kept in my previous vehicle. The long arm is too long so I'm going to cut it and re-thread it about four inches shorter. I was worried that it wouldn't be tall enough to clear the shifter but it is too tall and I do not get the range of motion I would like while keeping it somewhat below the dash. Now using my Delorme GPS is so much easier.
The only part that remains when the stand is not needed.
A good side profile to see the adjustability of the ball sockets. It can swing for driver viewing or into the lap of the passenger for easy use.
Laptop a humming away with the GPS pinpointing my parking spot of preference.
I didn't think that with three ball and socket joints it would be rigid enough to work but there is very little vibration transferred. I definitely recommend RAM components to anyone needing to mount electronics.
Old Feb 9, 2006 | 08:39 AM
bob200587's Avatar
any new devleopments on this sort of thing, I really need something like this for spring break, its a pretty long drive.
Old Feb 14, 2006 | 12:28 AM
ldivinag's Avatar
you can triangulate that setup by setting 2 other "arms" that bolts to the front 2 bolts of the passenger seat.
the arms can be anything. go wild on that.
spend an hour at home depot or something.
3 arms will make a very strong mount, even though the 2 can be skinny...
try here:
http://www.gpspassion.com/forumsen/t...TOPIC_ID=31517
Old Apr 2, 2006 | 06:28 AM
uberhahn's Avatar
do a search for Jotto Desk. You can find installed pics discoweb.org, among others.
very stable, if not a bit pricey.
Old Apr 4, 2006 | 07:02 AM
Roadrunner's Avatar
nermalgod,
How did you use to mount that ram ball joint, self-tapping screws or did you drill through the floor and attach with nuts and bolts? Thanks.
Old Apr 22, 2006 | 06:44 PM
nermalgod's Avatar
Nuts and bolts through the base. It was a pain to do as it was above the catalytic converter and behind the transfer case. Look before you drill. I don't think self tapping screws would hold the base securely enough.
LittleUgly
15
Jan 2, 2020 01:30 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
