GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Garmin 60CS
Old Apr 10, 2006 | 12:37 PM
Bob_98SR5's Avatar
Originally Posted by garrett1478
is this the mount you use?
yes, that is exactly it. dont even bother w/ the garmin or other mounts. the RAM ones are the BEST
Old Apr 10, 2006 | 12:40 PM
Bob_98SR5's Avatar
Originally Posted by paddlenbike
Bob, great review. Regarding the comment above, is it possible to have both the city map and the topo stored in memory and toggle between the two?
I am highly considering the Cx over the Cs. The Cx is $20 more and you gain the SIRF receiver and the SD microcard slot (very important for long trips) but loose 2 hours of battery life and the compass/barometer function. As long as I can store LOTS of maps on the SD card with the ability to toggle between city and topo, this unit should work nicely for me.
I appreciate any comments you may have.
Ken
Ken,
What's up, man It is *not* possible to store the city and the topo at the same time. That is probably the biggest shortcoming of the CS
i dont know anything about the Cx, but if you can store different maps on cards, i'd probably get that over the Cs. You konw, you'll probably use it in your vehicle 90% of the time anyways, so just get yourself a power cord. gpsgeek.com is a good place to get that kind of stuff. and as far as using the compass/barometer, no big deal. i dont think i've ever used that except when playing around with it.
Bob
Old Apr 10, 2006 | 01:34 PM
paddlenbike's Avatar
Hey Bob, miss me yet?
So the inability to store city and topo data isn't due to a lack of space on your Cs, but rather the unit can only store one type of map for a given area at a time? Ergh. I suppose instead of buying one 512 MB SD card I can buy two 256's with different maps on each. Swapping them will not be fun though.
Old Apr 10, 2006 | 01:35 PM
Bob_98SR5's Avatar
yeah, its a hardware issue. cannot store two different type of maps on the unit.
Old Apr 10, 2006 | 07:13 PM
  #25
Yup, you're absolutely right. I suppose you could get around this limitation by keeping road maps and topos on separate SD cards if you were worried about the road map hierarchy interfering with use of your topos.
Old Apr 18, 2006 | 04:17 PM
  #26
RobG's Avatar
Saw this thread a little late. I have the 76CS which is very similar to the 60. I can store both types of maps in the unit and it uses its hierarchy to select which map to use. By default it is City over Topo, But you can go into the setup features and change this manually on the unit, I think itis by location. I load both in and if I need to the Topo I switch it manually when I need it, usually after I get to the trail using the city maps.
Not sure if that helps anyone, I assume the the 60 has the same functions as the 76.
Old Apr 18, 2006 | 06:27 PM
  #27
Sure it helps; it sold me on the 76! Next time you switch maps, post back and let us know how you did it. Since I don't own one yet, I have to rely on the owner's manual, which says nothing about this capability. Thanks for posting!
Old Apr 18, 2006 | 07:37 PM
  #28
Bob_98SR5's Avatar
i dont think it does, but since you mentioned it, i will RTFM again
Old Apr 18, 2006 | 07:46 PM
  #29
AH64ID's Avatar
My vista C also has this feature. in the map setup page when looking at maps press the menu button, should give you the options.
What I wish is that I could view topo, but use city for routing. the topo is such a nicer view than city.
Old Apr 19, 2006 | 07:10 AM
  #30
RobG's Avatar
I skimmed the manual and couldn't find anything.
I found it by acciident once, I'll try it tonight when I get home.
Old Apr 19, 2006 | 09:17 PM
  #31
RobG's Avatar
Got it to Work on my 76CS.
Loaded all Socal Maps from Death Valley South to the Border, both City Select and Topo.
Get to the Map setup display. In the map screen press menu, map setup, scroll to the i (information) icon then use the cursor to deselect showing all the City maps. Reboot (Off-On) and the Topos display. The routing info from the city selects is no longer available, only info from the base maps. You can also get to the map setup display through the setup screen.
It's some what of a pain, but beats using the PC to reload the maps.
I assume it would work for a 60 as well, from what I understand inside they are the same unit.
Old Apr 20, 2006 | 04:38 AM
  #32
Marc P's Avatar
I need to get maps downloaded on my 60c. I have access to the topo maps, but I guess Iwill need to buy thecity maps. Does anyone have a bootleg version??
Old Apr 20, 2006 | 06:52 AM
  #33
RobG--thanks very much for taking the time to detail this; now I can buy with the confidence...
Old Apr 20, 2006 | 08:54 AM
  #34
RobG's Avatar
If you are going to buy based on that, let me try it back and forth a few more times tonight.
I'm confident the 60 will do the same thing, looks like most people here prefer that model. I find I need about 100M+ of memory to load everything I want, thats why the 76 works better for me. They didn't offer the x option when I bought mine.
Old Apr 20, 2006 | 09:02 AM
  #35
Jeffires's Avatar
Yes, the 60C works the same way. To use my BlueChart maps when I go fishing, I must enter Map Setup and disable all the City Select maps.
Old Apr 20, 2006 | 09:24 AM
  #36
Bob_98SR5's Avatar
boy, was i ever wrong then! i gotta try this out.
jeffires, where in the manual does it say you can do this? or is that al there is to it? press map setup?
bob
Old Apr 20, 2006 | 09:29 AM
  #37
Jeffires's Avatar
When I downloaded the BlueChart, it disabled the CitySelect. I looked for how to use both in the manual and on the website, and couldn't find it. I called Garmin and they explained to me that both could be loaded on the unit at once, but only one set could be active at once.
You must deselect all your topo, water, etc. maps to use the CitySelect, and vice versa.
Load all you want from the computer, then, on the Map view on the GPS, press Menu > Map Setup > then select or deselect each block.
Old Apr 20, 2006 | 09:42 AM
  #38
Bob_98SR5's Avatar
jeffires,
yup, that happened to me too and i couldnt find jack in the manual about switching between two maps. THANKS for the answer!
bob
Old Apr 20, 2006 | 09:50 AM
  #39
Jeffires's Avatar
Glad I could be of help- I'll have to say this as well- every time I have called Garmin, there has been a long wait to get through, but once you speak to a representative, they are very helpful, polite, and spend as much time as needed to help you understand your issue.
Old Apr 24, 2006 | 06:50 AM
  #40
RobG's Avatar
Looks Like Jeffires has it figured out and the 60 works the same way.
I tried activating and deactivating the different map sets and there is no problem going boack and forth from one to the other. To use City Select you don't have to deactivate the Topos, to Use topos you have to deselect City Select.
