GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Cobra 18WXSTII vs. 75WXST
Old Feb 22, 2007 | 08:28 PM
  #61
olharleyman's Avatar
Just a thought spend the money and find the mounting position for a corba 29 ltd theres so many mods that you can make to it to make it a very very nice radio that will talk for many miles side channels for when theres to many people on one channel and i would use a wilson 5 foot top load antenna looks same as firestick but a better antenna by far should be about the same price too. You will be best to go with 18 ft. co axel but just remember to say with 3 ft. incerments i.e. 3,6,9,12,15,18 18 being the best for setting swr
Old Feb 22, 2007 | 08:35 PM
  #62
I just noticed that your going thru Wallcot cb Very good place to by from had many of my ranger2950s and galixy 99s done by them in walcott iowa right accross from ta truckstop on i 80
Old Feb 22, 2007 | 09:22 PM
  #63
Turd Ferguson's Avatar
Ya'll are finding decent prices on the 18, but none are better than the one I found-- $49.99 at the local WalMart... Check 'em out before you sign on the line...
Old Feb 23, 2007 | 12:06 AM
  #64
Fink's Avatar
Looked at Wal-Mart but they didn't have it and couldn't order it I'm sure I could have gone to somebody with a cool colored vest on and checked to be sure the dude was right but I've tried to order stuff from Wal-Mart before...not the best place to do so.
Okay...so 18 feet of coax cable, I assume that if I can make CAT5 cable I can make coax cable right?
Thanks for the tips guys, the more information you guys give me the better I'll be so keep it all comin.
Fink
Old Feb 23, 2007 | 07:24 AM
  #65
Merlin's Avatar
It is not too hard to make coax at all. If you have a good-sized soldering iron/gun, you may want to get the solder-on ones rather than the crimp-on ones. As long as you're careful to separate the braids from the inner strand so you don't get a short and don't get too crazy with the solder, you'll be okay. The solder-on connectors are generally a little larger and stronger, so they'll make a more secure connection.
The instructions are generally right on the package and self-explanatory (usually have pictures - I like pictures). If not, there are tons of places on the web with equally good, if not more so, instructions.
And just a thought - you may want to buy more than one package of connectors (usually two in a pack) in case of mistakes for your first attempt.
Hope this helps,
Merlin
Old Mar 2, 2007 | 03:43 PM
  #66
Fink's Avatar
I am trying to finalize my order for all of the mounting hardware that I will need and am having a hard time with a few things.
Below is a link to the mount that I am going to get:
http://www.walcottcb.com/firestik-ss...unt-p-317.html
Here is the antenna that I am going to get:
http://www.walcottcb.com/product_info.php?products_id=901{2}44
My question is?what spring should I get? There are quite a few options, I want the one that will be the strongest and provide the most benefit.
Below is a list of links of all of the springs they carry at www.walcottcb.com I am assuming I need the Heavy Duty spring with the screw-on connection but I don't want to order all of this stuff and then get stuck with no spring...might as well do it right the first time.
SS3H - Stainless Steel Spring Item #: SS3H
http://www.walcottcb.com/firestik-ss...ing-p-585.html
SS3M - Stainless Steel Spring Item #: SS3M
http://www.walcottcb.com/firestik-ss...ing-p-584.html
SS34AH Combo. Heavy Duty "SS" Spring & Stud Mount Item #: SS34AH
http://www.walcottcb.com/firestik-ss...unt-p-824.html
SS34AM Combo. Medium Duty "SS" Spring & Stud Mount Item #: SS34AM
http://www.walcottcb.com/firestik-ss...unt-p-823.html
SS34H Combo. Heavy Duty "SS" Spring & Stud Mount Item #: SS34H
http://www.walcottcb.com/firestik-ss...unt-p-826.html
SS34M Combo. Medium Duty "SS" Spring & Stud Mount Item #: SS34M
http://www.walcottcb.com/firestik-ss...unt-p-825.html
Thanks guys!
Fink
Old Mar 9, 2007 | 12:40 PM
  #67
lee's Avatar
lee
bump...
new 19 is in, old 75 is out
Old Mar 9, 2007 | 12:58 PM
  #68
garrett1478's Avatar
why'd you switch?
Old Mar 9, 2007 | 03:11 PM
  #69
lee's Avatar
lee
the mic on the 75 wasnt loud enough for me.
Old Mar 9, 2007 | 03:14 PM
  #70
lee's Avatar
lee
an fyi in putting it... be prepared to cut your dash trim a fair amount.
also you may have to move some wiring.
my HU, sub and speaker wiring all hung down and in the way, so a majority of it had to be pushed to the upper right in order to get the cb in as far as it is.
also i ran new coax, and to do this, i removed the weatherstripping, resealed, then popped off the drivers side hatch wall (just popped around 5 snaps out), then removed the cargo cover holder (both the one behind the rear seats and the one at the very back of the truck), then i guided the wire using these openings, then led it down through the drivers side thresholds, then went directly under the carpet in front of the drivers seat and to the cb unit.
whew.
it was kinda a bitch but it was better than removing all the panels again.
Old Mar 9, 2007 | 05:48 PM
  #71
waskillywabbit's Avatar
Cobra external speaker hooks up the Cobra 75 with one plug in...piece of cake and LOUD as you want it to be.
Old Mar 10, 2007 | 02:23 PM
  #72
Fink's Avatar
Does anybody know which of the springs listed above I should get?
I'm waiting to order the stuff cause I don't know which one will work.
Thanks guys!
Fink
Old Mar 11, 2007 | 03:28 AM
  #73
Mtriple's Avatar
Thanks guys!
Fink
I ordered the SS3H just the other day as the SS3M is only rated for 2 to 3 foot antennas. I'm using a 4 foot Firestik II so I went with the heavier spring. I know that some guys have complained that with the medium spring, the antenna sways quite a bit and depending on where you mount the antenna it could hit your truck.
Old Mar 11, 2007 | 05:22 AM
  #74
881stGenRunner's Avatar
i just bought a cobra 18WXSTII and a 3' Firestik II antenna, do i need a spring for a 3' antenna?
ashamsuddin
17
Jul 22, 2024 03:59 AM
shisha1999
Sep 21, 2015 08:22 PM
mxdw88
Sep 20, 2015 03:13 AM
AndYota
Aug 10, 2015 09:19 AM
msane99
Jul 11, 2015 08:08 PM
