GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB died need help fixing
Old Jun 20, 2010 | 08:48 PM
1981 yota's Avatar
my cb died on me last time i went on a drive on some green dot roads it was working fine then it just shut off and wouldent turn back on after checking every thing it blew the cbs fuse and the radio fuse after going to napa and getting new fuses the radio worked fine but the cb would turn on and blow the fuse and turn back off i moved the ground to a better place and still didnt work.
so i cant figure out whats wrong please help.
my cb is a cobra 78x
[IMG][/IMG]
thanks for any help
Cody
Old Jun 20, 2010 | 08:51 PM
Elton's Avatar
that cb looks old ! maybe time just to get a new one
Old Jun 20, 2010 | 08:54 PM
1981 yota's Avatar
ya it from the 80s but it worked great for about 1 month
Old Jun 21, 2010 | 09:56 AM
swampfox's Avatar
check the wires for a bare spot .also check the power plug on the back. you can also smell the cb and see if there is a burnt smell. if there is a burnt smell it has something wrong in side.the cobras have a diode inside ,if i remember right to protect them from power on the neg wire. it will keep it from working but it usually won't pop the fuse if it is bad. also if it has a cigerette lighter plug on it, take it apart and make sure the wires arn't touching.
Old Jun 22, 2010 | 04:56 PM
Merlin's Avatar
^^ what he said... i would suspect a short somewhere from being bounced around, maybe a loose wire.
maybe moisture in the radio somewhere? i used to bring my radio in from the car in the winter, but i think that was worse than leaving it in the cold (like -30 cold) because it died soon after (first couple of weeks of winter).
i was told moisture probably condensed in there, then when i put it back into the car and turned it on something probably shorted.
Old Jun 30, 2010 | 05:50 PM
85gijunk4x4's Avatar
lol ill hook you up with a new (used) one lol.
where the heck have you been...havnt heard from ya in a while
polo451
13
Nov 20, 2016 07:49 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
87toyy
Aug 4, 2015 04:51 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
