CB Controls . . .
Can anyone describe to me exactly what the squelch control does? It doesn't seem to affect the volume, power, strength etc. although I've only tested it short range.
Squelch can be a problem at long transmission distances because transmssions will be much closer to the static's power, and you may accidentally filter transmissions out as well.
Make sense?
It filters out background noise. If you change to a channel with your CB, and there is a lot of static noise, you can turn up the squelch until the static is no longer there. It will basically filter out any signals below a certain strength (or at least not play them through the speaker), so static is not registered, but a transmission with greater power than the static will come through.
Make sense?
Make sense?
Erich
kawazx636
Oct 6, 2021 03:03 PM
aowRS
Sep 13, 2017 08:22 AM
kcaudill
Oct 10, 2015 02:39 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
