GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
can GPS do hill elevations?
Old May 25, 2005 | 05:28 AM
jacksonpt's Avatar
Senior Member
I assume most decent GPS units have an altimiter built in, no? Can they spit out hill profiles like this, or would I need some type of additional software?
Old May 25, 2005 | 05:51 AM
WATRD's Avatar
Most GPS units can do what you are seeking when combined with the correct software.
Here's the profile from the "Fall Colors" run last year;
Old May 25, 2005 | 06:36 AM
cubuff4runner's Avatar
As Rob said with the proper software most newer GPS can track altitude and map it; however, the accuracy can greatly differ depending on the unit. Most cheaper GPS's will calculate you elevation the same way they calculate you location by triangulating information from numerous satelites. More expensive models will typically have an altimeter built into them to provide more accuracy. For mapping trails you really don't need a few foot accuracy on you altitude IMO.
Old May 25, 2005 | 07:21 AM
jacksonpt's Avatar
Senior Member
Ah, that's good to know. I want it to map out bicycling routes, including distance and elevation change... so accuracy is pretty important. I don't need it to be within 1' accurate, but I do need it to be within, say, 10' of acurate.
Old May 25, 2005 | 08:00 AM
Jeffires's Avatar
I think that on a GPS without the altimeter, the elevation is the least accurate reading. It seems to me that speed and location are near perfect, but to get a very accurate elevation reading, a GPS with a "sensing" altimeter is needed. I purchased the Garmin GPS 60CS because it included a few more features (altimeter) than the 60C.
Old May 25, 2005 | 12:43 PM
4x4Lamm's Avatar
Etrex summit can do that.
Lamm
Old May 26, 2005 | 04:05 AM
jacksonpt's Avatar
Senior Member
yea, that's the one I was looking at.
Plus, with a name like Summit, it had better be able to do that kind of thing, and it had better have a true altimeter built in.
kbpickens
Oct 2, 2015 03:37 PM
Sam hain
19
Sep 30, 2015 08:25 AM
charlie_fong
Sep 27, 2015 10:06 PM
noahstancik
Sep 10, 2015 10:47 AM
markf1
Sep 3, 2015 01:23 AM
