Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
XM install for a 2003 4runner limited w/ JBL and in-dash 6cd changer
Old Jun 13, 2004 | 04:51 PM
UA4runner's Avatar
Question XM install for a 2003 4runner limited w/ JBL and in-dash 6cd changer
At first I thought about going with an aftermarket head unit but I couldn't find anybody that makes a dash kit for my 4runner yet. I also don't know if anybody makes a wiring harness yet either because of the JBL amps.
So for now I think I want to go with XM. I absolutely don't want to go FM Modulation unless I have to.
The PIE and BlitzSafe adapters are supposed to work with any 2003 Toyota models w/o the navigation system but it says to use the 12 pin port for the optional 6-disc cd changer. What if my head unit IS a 6-disc changer? Will you still have the port? (I plan on calling PIE or BlitzSafe but wondered if anyone else had tried this)
Any recommendations on PIE v/s BlitzSafe?
Any recommendations on Delphi SkyFi/Roady or XM Commander?
Old Jun 13, 2004 | 05:21 PM
r0cky's Avatar
I'd be interested in hearing what people have to say about this as well!
http://www.xmfanstore.com
there are tons of XM double din head units to replace the stock setup too.
http://www.xmfanstore.com/showproduct.php?id=pieoem
if you go to that link, there is a pdf file for vehicle compatibility and toyota is on page 6 ... just in case that says something different.
Old Jun 13, 2004 | 06:25 PM
waskillywabbit's Avatar
Talking Ua
UA as in what UA? The University of Alabama?
Old Jun 13, 2004 | 07:43 PM
SD4Runner's Avatar
I'm thinking of going XM , but NOT FM Modulation... I have read quite a few threads, I am interested to find out what you decide.
Old Jun 13, 2004 | 08:12 PM
RapidRunner's Avatar
I, too, am waiting for a more permanent solution once Scosche or someone has the adapter to put in a new head unit. For now I've got a Raody. I'm using a tape adapter and it sounds a lot better than the RF modulator in the wife's Sequoia -- but I'd rather direct connect if the Blitzsafe worked -- let us know.
If you want a Roady, you can get it for 49 bucks if you sign up for 3 months by buying it here.
https://xmradio.metrononline.com/xmp...cesslogin.aspx
Enter code XMDPHXM04
Do it quick, though -- the last code expired in like a week or so.
BTW -- I originally got this deal off http://bensbargains.net and then got the updated code at http://www.fatwallet.com -- so I'm not taking credit for it!
Old Jun 15, 2004 | 06:21 PM
UA4runner's Avatar
Yeah I graduated and moved from Tuscaloosa a couple of years ago.
Old Jun 15, 2004 | 06:56 PM
UA4runner's Avatar
That's a sweet deal on the Roady...Are they better than the SkyFi or XM Commander?
Interesting that you say the tape adapter sounds better. I got the impression the FM modulator would sound better - but still not as good as direct connect. You are out of luck anyway if you have the 6-disc in-dash changer. The direct connect modules are supposed to plug in at the connection for an EXTERNAL changer. So I'm pretty sure that won't exist if you have the in-dash changer.
I talked to a guy a Crutchfield and was told they would have a DIN adapter at the end of the month and the people at http://americaninternational.net/ told me the same thing. Bad news is they don't expect to have a wiring converter anytime soon to go with the JBL amps.
So to make a long story short, I think I'll just save up to buy a head unit and wait for the adapter.
Old Jun 15, 2004 | 07:07 PM
UA4runner's Avatar
One more thing...
Does the security system work through the factory head unit in the '03s?
If so I'm SOL.
Old Jun 16, 2004 | 05:53 AM
nrgetic99's Avatar
Scosche have a nice looking single DIN head unit adaptor if that is what you meant. The lower space is a little cubby that canl be upgraded down the road to a little CD holder (kinda slide out draw dealy)
Scosche TA2044.
When mine is in place, I will post pics.
David
David
Esibnitsud
Jul 30, 2015 08:19 PM
cruisinPB
Apr 26, 2005 06:43 AM
SUINAT
Jan 12, 2005 07:04 PM
UA4runner
Jun 30, 2004 06:30 PM
4runnerwv
Jun 22, 2004 05:51 AM
