Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
When using the CD Player only getting sound from 4 speakers...
Old Sep 19, 2005 | 08:52 PM
sadiq's Avatar
Okay I have a '95 4runner w/ 6 speakers from the facotry(2 in the front/dash, 2 in the back cargo area and 2 all the way in the back above the rear window).
Like 2 days after I got the truck 3 years ago I installed an after market Panosonic CD Player, and 2 after market infinity speakers in front 'cause one of the stockers was blown out.
Here is what I've noticed: when listening to the Radio it actually sounds great, decent bass, and supringsly clear. Okay when I play the CD Player its nothing but highs...its clear but no bass at all.
What I've recently realized is that when the radio is working all 6 speakers are pumping out sound but when the CD is playing only the front speakers and 2 small speakers on top the rear window work???
Obviously if the side panel rear speakers aren't working there is going to be a lack of bass.
Any suggestions or ideas?
Thanks.
Old Sep 19, 2005 | 10:54 PM
rider_1313's Avatar
yeah, i would hook up the remote wire for the cd player so that the amp that powers those side speakers goes on when you are playing a cd. that would help solve your problem. (just tie both blue wires together)
Old Sep 20, 2005 | 08:39 PM
tombothetominator's Avatar
The only problem you have (or i had) when you tie both blue wires together is that your antenna goes up any time you are listening to ANYTHING. Dont know about you, but it drove me nuts. Put a CD in and up goes the mast. I added a switch for the antenna so that i could control when it goes up and when it doesnt. May not be something you care about, just wanted to make sure you were aware.
Old Sep 21, 2005 | 08:00 PM
admiral's Avatar
https://www.yotatech.com/forums/f96/1992-4runner-67621/, I had the same problem, this is how it was solved.
Old Sep 21, 2005 | 11:03 PM
rider_1313's Avatar
if you have a power antenna, there will be two remotes on the wire harness, and there are usually two remotes on the head unit also. one should only go on with the radio, and the other should always go on. i only said to hook them both together, because i did not realize that the 95' had a power antenna, and it was less to explaine.
but if it does have a power antenna, just look at the lable on the wire, or get out a volt metter and see which one goes on all the time and hook it up to the speaker amp, and the one that goes with the radio would go tho the antenna.
Old Sep 22, 2005 | 07:01 AM
sadiq's Avatar
Originally Posted by admiral
https://www.yotatech.com/forums/showthread.php?t=67621, I had the same problem, this is how it was solved.
Thanks man...I'm going to fix the problem this weekend. So basically the guys at Circuit City that installed it had no idea of this? See what you get for the "free installation" specials!
Did you stereo pump out all "highs" when playing a CD before? I'm looking foward to my stereo to sound a lot better in CD.
Old Sep 23, 2005 | 03:00 PM
admiral's Avatar
Yes, it was all I had was highs and my two 10" woofers bumping out the bass, now it sounds way better. Glad to help.
Old Sep 25, 2005 | 08:43 PM
sadiq's Avatar
fixed it on Saturday afternoon....sounds much better! thanks guys for the help!
another yotatech success story!
Old Sep 25, 2005 | 09:01 PM
Tofer's Avatar
Sponsor
i did that too, i was tired of buying new antennas after wheelin trips.
Marley2984
Dec 6, 2015 05:19 AM
toyotasaurus
Sep 24, 2015 03:30 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
