Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Switchable +12v power source?
Old May 11, 2005 | 11:47 AM
titanium4runner's Avatar
Question Switchable +12v power source?
Where can i find a +12v switchable power source in a 2001 4runner to power up a sirius satalite radio in the dash? thanks in advance
Old May 12, 2005 | 01:05 AM
kevin444's Avatar
Do the full time power outlet mod, Tap into the two lines of the one of the power outlets and add a inline switch at the same time. = )
Old May 12, 2005 | 03:10 AM
dibble9012's Avatar
The ACC fuse under the dash, that turns on with the key at ACC and ON. It should be fine as the Sat Radio does not take much power.
Old May 12, 2005 | 08:37 AM
yea the acc is fuse is where i ran the wire, but i was wanting to clean up the install a little bit. i was hoping there was a power source behind the dash. on the outlet there are 2 wires ... are these the same wire just with an outlet in the middle? (meaning either side would be ok to cut?)
Old May 12, 2005 | 09:03 AM
dibble9012's Avatar
do you mean the power outlets? you would want to cut the positive side, it would be the wire that connects to the center prong in the outlet, the ground is the outer "shell".
Old May 13, 2005 | 06:30 PM
yea thats i what im talking about, do you have a picture of the wire that i would tap into? or color of the wire would help. I was wanting to do this but didnt want to cut the wrong one. thanks for your help
Old May 14, 2005 | 07:05 AM
Bumpin' Yota's Avatar
oh dear god...
Ok first go to harbour freight tools and buy a 3.99 DMM. (Digital Multi Meter)
Now use the DMM to determine which wires on those cigarrette lighters are carrying 12v's and which ones are ground. (If you mess up the polarity the DMM will tell you by giving you a negative voltage.) And all you have to do to make sure that the cigarette lighters shut down is to turn off the key and see if the voltage drops to zero.
I do install on these things like popcorn - 60 min and im done and you see NO wires at all!
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
gmonnie123
Jul 26, 2015 02:44 PM
shar
Jul 9, 2015 12:38 PM
cyclist231
Jul 7, 2015 12:56 PM
