Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Subs for a 05 Tundra Access Cab
Old Dec 27, 2004 | 11:13 AM
2jmotorsports's Avatar
I have an 05 Tundra Access Cab with the CD/Tape deck & front door tweeters. For some more bass, I have an idea but I want to know what you guys think:
IF they fit, I wanted to replace the rear door speakers with a pair of JL Audio 6W0 6.5" subs. If necessary I can machine some adapters to screw them in. Since they are relatively low-powered (I think 75W RMS) I could probably run them off of a small 100-150W amp that would be easy to mount under one of the front seats or maybe I can sacrifice some of the space under the rear seat.
So far I have only seen the JL Audio enclosure that takes up nearly all of the center console or the one that will mount 2 8" subs under the right rear passenger seat. My only problem is that I want to sacrifice as little storage space as possible. I know these tiny subs wont rattle windows on the whole block but thats ok, I just want decent bass inside the cab.
How does this sound? Any problems you guys forsee? Thanks in advance.
Old Jan 5, 2005 | 01:33 PM
Duffdog's Avatar
if you replace the mids with woofers, what are you going to do about mids?
BTW-- I tried this setup with 4 6.5" mids-- 2 in each door ( sounded weak, even with a 400watt amp )
T
Old Jan 5, 2005 | 03:08 PM
Well I still have some mids in the front doors and those sound waay better than the ones in the back. JL advertises their 6W0's as "true" subs, which is why Im thinkin about em in the first place; otherwise I wouldnt just stick another pair of mids in there and expect them to sound like subs. Ive never heard the 6W0's so I dont know how good they are. Figured I would ask first...
r3dfish
54
May 16, 2016 10:31 PM
matrad
Aug 8, 2015 03:00 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Esibnitsud
Jul 30, 2015 08:19 PM
