Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
So you think you have a 500watt amp?
Old Apr 18, 2006 | 12:37 PM
NisAznMonk's Avatar
What do you think of this amp?
Old Apr 18, 2006 | 12:38 PM
Localmotion's Avatar
did you make that?
thats jawesome! now go get it powdercoated from J!
Old Apr 18, 2006 | 12:48 PM
cootees's Avatar
Originally Posted by Localmotion
did you make that?
Old Apr 18, 2006 | 01:36 PM
DavidA's Avatar
Now that is just plain fraud. Silly. Or maybe it is upgradeable...rightttttttt....
Old Apr 18, 2006 | 01:43 PM
Turd Ferguson's Avatar
Where's the capacitors? That tiny little transformer has to put the juice somewhere or it'll do nothing but suck power down the line from your battery...
Either that or I'm overanalyzing again.
Old Apr 18, 2006 | 02:14 PM
midiwall's Avatar
Have you fired it up yet? You may end up with some resonance issues from the small coil on channel 1. That winding looks pretty off...
And Mr. Turd has a point - you're gonna wanna run some good sized caps on the leading edge.
I trust that's a straight up Class A design? There's nothing more on the underside of the board, right?
Old Apr 19, 2006 | 08:53 AM
NisAznMonk's Avatar
WOW I really hope some of you were actually being sarcastic with your overanalyzed posts.
Either way I stole those pics off of www.realmofexcursion.com under the brand name Wharf. I always love looking at amps where most of the chassis is filled with air. I guess you can make power off of oxygen
Old Apr 19, 2006 | 09:41 AM
midiwall's Avatar
Ahh... so it's not yours!
Yeah, actually that amp looks pretty straight forward. If you flipped the board over you'd find the power transistors which are the actual "amplifiers". They'll be mounted to the heat sink (black plate) for heat dispersion.
It looks like it would be a Class B amp (I was wrong before in saying Class A) - one that amplifies only one side of a signal.
There's really not much in an amp... you can "amplify" a signal with very few components, a lot of the side work is there to keep things under control, provide for clipping protection, noise filtering, DC isolation, etc.
The air space is for real... Cranked up that thing will generate a lot of heat, and you need to combat it with air space. The mechanical design there is more about having enough physical space for the heat sink and not about the air inside the cabinet (though it helps, but it would help more if there were vent holes). It looks like he didn't want to run a fan, so he's looking to bleed off heat with only a sink. It's a valid design choice...
Old Apr 19, 2006 | 09:49 AM
Tacoclimber's Avatar
Like, wow, man.....my head hurts now....
Old Apr 21, 2006 | 02:12 PM
Bumpin' Yota's Avatar
...The air space is for real... Cranked up that thing will generate a lot of heat, and you need to combat it with air space. The mechanical design there is more about having enough physical space for the heat sink and not about the air inside the cabinet (though it helps, but it would help more if there were vent holes). It looks like he didn't want to run a fan, so he's looking to bleed off heat with only a sink. It's a valid design choice...
While I'm no designer of amps, I am a bit skeptical of needing THAT much air space...lol My MTX 81000d's had no fans and would operate hours on end running WAY below recommended impeadance. Even my incriminator 20.1s (1800w rms @ 1ohm) have zero issues despite having no fan and running at 0.35 dcr. (though they do get warm after about 3 hours of play time.)
The difference I think may be that both the 81000d and the 20.1 tip the scales at over 22lbs each from their massive aluminum heatsinks. Maybe the pictured amp has that much airspace because the heat sink isn't massive enough to dissipate the heat the transformers produce? Is that what you meant?
Old Apr 21, 2006 | 02:42 PM
midiwall's Avatar
Oh, I don't think it does eider! I'm pretty sure the air space is there only 'cause he ran that huge arse heat sink.
Oh wait... I guess my post is a bit sideways huh? Sorry..
Yes, I agree that I don't think that amp is kicking enough to justify that large of a heatsink, though it will get pretty warm. And of course the air space is a side effect of the heat sink. My guess is that the guy winged it without actually doing any math or tyring the circuit. _SOME_ heat is okay, a lot of course is bad. I'd bet that he wanted that thing to run ice cold.
If that's the design I think it is, then basically power output will only really be dependent on how much power it can suck off of the DC. As long as you keep the outputs from toasting, it should keep on going.
I'd bet that he got a surprise when he first kicked it on.
Old Apr 23, 2006 | 09:34 AM
Bumpin-
Remember the old Xtant 1001 series amps? You could daisy chain them together and run 2000 watts RMS at .5 Ohm stable and it wouldn't roast itself... IIRC a lot of that stuff went into the MTX's once the takeover was completed.
Old Apr 30, 2006 | 11:23 PM
ldivinag's Avatar
lemme give you a funny story...
a fewwwwwww years ago, probably early 90s, at the vegas CES show (back then vegas was the winter and chicago was the summer show), i was browsing the high end audio part.
this one room, i saw a typical home amp. gigantic box. but with a sign that says something like "great sounding up, $500"...
it was surpising since we all know typical high end home audio amps like to run in the four figures (and more).
until they propped the chassis and it revealed the (then) great PHOENIX GOLD legendary MPS-50 (man i hope that was the model #) amp.
a big box containing a typical car audio amp... lol......
Old Jun 11, 2006 | 11:42 AM
4-RUNNIN' FREAK's Avatar
200 watt Firestorm amp
Old Jun 12, 2006 | 02:03 PM
Greg_Canada's Avatar
No i think i have 800w RMS (at 12v)
Old Jun 12, 2006 | 02:22 PM
lofreqjeff's Avatar
This is what the board of a REAL amp looks like:
This is one of my Xtant 3300x's
Its a 3/5 Channel; aprox 750 watts RMS when I run it 5 channel at 2 ohms and 1150 watts RMS when I run it at 1/2 ohm
Old Jun 12, 2006 | 03:41 PM
ldivinag's Avatar
CHEATER AMP... CHEATER AMP... CHEATER AMP.... [sound the sirens...]
lol...
that and a phoenix gold... and RF... and PPI... ahhhh... the older days of car stereo...
bring the load down to 1/2 ohm. i remember seeing a van using a 2x50 amp, but it had close to 10-14 speakers... lol.... the passive crossover network took like a whole door to mount.
Old Jun 12, 2006 | 04:51 PM
freshman's Avatar
im selling mine now over ebay. 3 days to go.
phoenix gold ms 275. a real amp!
sorry for the hi jack....
Old Jun 12, 2006 | 06:19 PM
ldivinag's Avatar
there's 2 MS275 on fleabay... which one is yours?
when i finally got a "paying" job, one of the first things was that or soundstream reference series amps...
a local shop was selling refurbed SS REF series amps for a killer price... those suckers lasted me like 6 years... sigh...
they dont make amps like they used to...
Old Jun 12, 2006 | 08:06 PM
no boys, THESE are REAL amps!
each one is rated at 2200w rms x 1 @ 2ohm mono.
Real world output? 1890 watts at 45hz each with battery voltage sagging to below 10v. (Yes with all 4 going at the same time!) I have never tested any amps that were more powerful, though the 20.1 incriminator audio comes close... Keep in mind that 1 of the above amps puts out more power on a limited current supply than a pair of rockford BD1500s or a pair of MTX 1501d's...
btw keep in mind most good amps fail to do 70% of rated output with plenty of current and voltage behind them...
