Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Scosche TA02B does NOT match the pins from a 98 4runner stock wiring harness
Old Feb 15, 2006 | 06:04 PM
98arrunner's Avatar
I have a 98 runner, and was trying to install a sony 7715. After taking out the stock unit (tape only), I discovered that the scosche TA02B wiring harness does NOT match with the pins from stock wiring harness. I looked at the wiring diagram posted either here or installdr, and it seems my runner has a different pin layout from the others. Here is the pin layout from the stock wiring harness (female end--for lack of better words):
1st one
second one:
Pin layout of TA02B:
1st one:
second one:
Is there a different wiring harness adaptor I need to buy? If so, what model?
Just wanted to check with you guys before I cut the stock wiring harness.
Thanks a lot!
Old Feb 15, 2006 | 07:41 PM
edikp's Avatar
Just checked on scosche.com; none of the results for '98 4Runner was TA02B. There were T02R and T02. You might want to check Scosche's website.
Old Feb 15, 2006 | 08:03 PM
98arrunner's Avatar
edikp, thank you for spending time looking it up for me.
i spent an hour digging around, and found out that the other end of the stock wiring harness was connected to a device (don't know exactly what it is, maybe converter?--haven't had time to check it out) where two factory wiring harnesses connected to. i yanked out the "converter", and the two wiring harness matched ta02b perfectly.
i don't know why the "converter" was there, if anyone can explain what it does, that would be great!
thanks to all.
Old Feb 15, 2006 | 08:11 PM
edikp's Avatar
A device? Rectangular? Probably the stock power amp?
Old Feb 16, 2006 | 06:55 AM
DavidA's Avatar
Yeah...the harnes goes out of the stock radio into the amp, a small box mounted below the radio. That is your harness. Good luck.
Old Feb 16, 2006 | 07:00 AM
Bob_98SR5's Avatar
98,
you should definitely search around the site, including the tech section. i have a writeup on how to do exactly what you are trying to do in the tech section under the "electrical" subforum of the tech section
bob
Old Feb 16, 2006 | 07:27 PM
98arrunner's Avatar
I got it installed. Thanks for the help.
Old Feb 20, 2006 | 04:34 AM
Bumpin' Yota's Avatar
98 - I know you got it installed, however I would suggest trying to integrate the factory amp. Reason being nothing sucks like a deck's amp. A metra 808112 amplifer integration harness would work beautifully, the only requirements are that your deck have 2 sets of RCA jacks.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Yota.Jay
Mar 6, 2016 11:02 PM
TheManOutside
Jun 18, 2015 03:32 PM
RTdawgs
Jun 1, 2002 06:36 AM
