Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
radio off at lights
Old Apr 27, 2011 | 08:24 AM
dd210's Avatar
radio off at lights
1998 4runner
after market deck checked all connections fuses ok so know I really dont know plugged back in my stock radio in and now the lights on the dash/ac do not come one when the headlights are on
bought the aftermarket wires so I did not have to cut my wire harness
drive around stop at a light the radio only sometimes will flicker on and of which makes the power antenna go up and down
put stock radio in and now all my lights on the dash and ac are off with head lights on
Old Apr 27, 2011 | 08:49 AM
michael1963's Avatar
For a second there, reading your title, I thought you meant your radio would go off at a set of traffic lights.
Old Apr 27, 2011 | 09:15 AM
WHAHAHAJR's Avatar
check your grounds
Old Jun 14, 2011 | 07:55 AM
i also say check your grounds but it looks as if the aftermarket works fine and the stock doesn't? If that is the case, maybe something happened to the stock radio while it sat and is causing the problems. maybe your grounds are loose or the antenna wire is not plugged in good too. also, check your fuses too
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
AkitaDog
Sep 1, 2015 08:05 AM
Mrhoadley
Aug 4, 2015 06:08 PM
TDonkey
Jul 26, 2015 10:14 AM
