Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Radio interference question
Old Jul 3, 2014 | 03:30 PM
JasonYota's Avatar
Here's what's happening, I have a radio in my boat and usually get good signal with local stations although I was listening to the radio while piddling in the yard and noticed when I plugged in my phone charger in a separate 12v outlet the signal went almost completely out. Lots of static, I have not noticed this with a spot light (main reason of the 12v outlet).
Wouldn't really be a problem to charge a phone out on the water if need be but is there anything I could do to prevent this?
Old Jul 4, 2014 | 09:15 PM
drpdmazda's Avatar
the charger and the radio share the same ground, that is whats causing the interference. beings that its a boat, i doubt you have many if any options for ground points aside from the battery negative terminal. if you do have another ground option try grounding the radio at a different spot.
Old Jul 4, 2014 | 09:19 PM
vital22re's Avatar
totally a bro
^that and you may need to add noise filters to the power source just to rule out variations in voltage.
Old Jul 5, 2014 | 10:18 AM
JasonYota's Avatar
Yes everything is wired through a fuse block going back to the starting battery. Just thought it was odd the radio has only done that with my phone charger. Doesn't do it with anything else running that's tied into the fuse block.
Old Jul 14, 2014 | 08:54 AM
drpdmazda's Avatar
do not question the gremlins of electricity, you will regret it if you do. haha. small phone chargers are hard to keep quiet, lots of high powered stuff and tinfoil inside of them.
80Truck
Oct 12, 2025 07:25 PM
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
Littlerick
Sep 10, 2015 08:57 PM
Mrhoadley
Aug 4, 2015 06:08 PM
