Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Quick help needed-Headunit Wiring Colors
Old Aug 1, 2005 | 09:29 PM
964runner's Avatar
Exclamation Quick help needed-Headunit Wiring Colors
I am in the middle of wiring my new deck does anyone know what colors are the wires that go from the stock deck to the speakers?
Old Aug 1, 2005 | 09:30 PM
Bob_98SR5's Avatar
look in the wiring database at www.the12volt.com
Old Aug 1, 2005 | 09:45 PM
NisAznMonk's Avatar
Are you cutting your factory harness?
Old Aug 1, 2005 | 09:55 PM
964runner's Avatar
yes is something wrong with that? its not like im goin back to my stock deck anyways
Old Aug 1, 2005 | 10:10 PM
AW1090's Avatar
you can do it that way or you can run down and pick up a wiring harness for your truck. If you ever decide to sell your truck you could stick the factory deck back in it.
Old Aug 1, 2005 | 10:37 PM
Bob_98SR5's Avatar
if you want to do it this way, so be it, but yes, you ar e making it much more difficult on yourself by doing it this way.
bob
Old Aug 1, 2005 | 10:40 PM
NisAznMonk's Avatar
Well its up to you. Having the correct harness will make your job MUCH easier. I think its like $10 at Walmart too. Not a bad investment, but good luck
Old Aug 1, 2005 | 11:01 PM
Bob_98SR5's Avatar
...and you might also want to search the various head unit installations (using those key words) before you continue.
bob
Old Aug 1, 2005 | 11:05 PM
Bumpin' Yota's Avatar
No offense intended, but I see these 'installs' every day at work and im the one paid to fix them...
If you dont know off the top of your head the oem wiring colors and more importantly how to double check them, do not even attempt it!! Go to wallmart and buy the scoche universal toyota harness or go to Circuit City and buy the Met 801761 harness!!!!! At wal mart it will cost you 8 bux, at CC 15, either way saving you a lot of time and effort.
When you tie the scoche/metra harness to the decks harness, silver solder then electrical tape - none of that butt connector crap!
Big pet peeve struck on this post....
Old Aug 2, 2005 | 05:17 AM
Astralplane's Avatar
Metra now even makes a "smart" wire harness that requires no splicing for most HU brands.
Plug one end into your rig the other end into the HU - DONE!
Circuit City should have them.
It least use a std harness, that will allow you to tie the wires together at a workbench instead of up under your dash.
Old Aug 2, 2005 | 05:40 AM
Actually at CC we dont have that exact metra type - instead we have car side harnesses and radio side harness that all use the same universal molex. This way when you change decks you only have to buy another radio side harness - the new one plugs into your old car side harness! Very cool, but if you dont buy them in an installation package the pair costs you about 30 bux.
Ive literally done dozens of hardwires on vehicles - I HATE doing it! And 9x out of 10 the fuses are also blown because the person doing it didnt realize that making the ground touch constant will blow fuses like popcorn....
Old Aug 2, 2005 | 06:56 AM
964runner's Avatar
thanks for everyones input, but i wasnt asking what i shouldve done, I aready know that, I was asking what colors are the wires so I can finish the job, thanks
Old Aug 2, 2005 | 08:21 AM
ok Ill go look up the colors for you from our technical database when i get back to work on thursday. Remember to double check every wire with a DMM before ya hook it up to the radio - databases such as these are often incorrect. If you need any help with that lemme know.
Old Aug 2, 2005 | 08:26 AM
As found on www.12volt.com im still posting back with what CC's databases say should it be different. Just be sure to DOUBLE check this stuff could be wrong! Also make sure all 4 speakers are in phase - this is easily done with any 9v battery.
1999 Toyota 4-Runner Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Purple
Dimmer n/a
Antenna Trigger Black/White (Antenna Right Front)
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Doors
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
Old Aug 2, 2005 | 08:54 AM
964runner's Avatar
that helps me alot, thank you. What is the phase thing your talking about?
Old Aug 2, 2005 | 08:55 AM
964runner's Avatar
o yea and whats a DMM
Old Aug 2, 2005 | 11:59 AM
the phasing thing is basically ensuring that all 4 speakers act as one - so make sure your negatives are negatvies and hooked up to negative and the same for the positive. If you are unsure have a buddy look at the speaker, then then place a 9v in parallel with the speaker up by the radio. If the speaker pops out then the positive terminal on the battery is contacting the positive speaker lead and the same for the negative.
Should the speaker pull in when its popped by the 9v, you have the negative speaker lead on the 9v's positive terminal. A nifty little trick most installers use
A DMM is known as a digital multimeter - THE single most handy tool I own. They can be bought at Harbour Freight tools for 4 - 5 dollars and are more than accurate enough for car audio work. They allow you to measure resistance from 0ohms up to several ten million ohms, measure for continuity, measure AC voltage (house hold voltage) up to 600v, measure DC voltage (car use) again up to several hundered volts, can test diodes, and can even serve as small inline anmeters! Ultra ultra useful little buggers. The nice thing about a DMM is that it also has a very high internal resistance so if you probe the wrong wire you wont deploy an airbag, unlike your standard test light.
Old Aug 2, 2005 | 12:10 PM
964runner's Avatar
okay after 3 hours of frustration I tookeveryones advice and went and bought a harness, now i have to re wire the stock harness
but live and learn right
Old Aug 2, 2005 | 06:51 PM
94x4's Avatar
Guest
One can only hope.
Old Aug 2, 2005 | 08:07 PM
hehehehe since you were in there, after you resolder on the OEM harness and plug in the metra/scoche harness, you can compare the wires just for comparison sake to see iif you were on the right track.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
