Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
problem with alpine HU install
Old Feb 26, 2006 | 05:48 PM
TX2RUNNER1997's Avatar
ok, so i was trying to install my new alpine cda-9833 HU tonight, and i had finished wiring up the unit with the appopriate metra wiring harness. problem is, when i get everything hooked up....no sound whatsoever. ive checked and checked and i cant find an issue with my wiring, i connected everything correctly. i have a 97 limited tr4. does anyone know what the issue might be?
Old Feb 26, 2006 | 05:53 PM
freshman's Avatar
by pass the factory amp? i'm guessing....
Old Feb 26, 2006 | 05:57 PM
Bob_98SR5's Avatar
http://www.4runners.org/articles/headunit
make sure you follow the same procedure here.
assuming you are just making a head unit change and nothing else:
- did you unplug and remove the amp?
- did you wire everything up correctly?
- is the mute button on?
- did you unplug the speakers?
my best guess is that you may have not wired it correctly
bob
Old Feb 26, 2006 | 06:09 PM
i bypassed the amp but i didnt find a place on that metra harness for the mute (audio interrupt) wire to go to. i figure that must be the issue. any suggestions?
Old Feb 27, 2006 | 07:28 PM
haha figured it out i just had to turn the internal amp on the HU
icentropy
Sep 16, 2020 02:47 PM
rushw
Jul 18, 2015 01:46 PM
Coreyr384
Jul 10, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
bryan34w
Jul 6, 2015 05:53 PM
