Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
no sound from deck, no pwr from amp
Old Apr 1, 2009 | 07:19 PM
sinneDBTB's Avatar
i have a sony xplod 4 channel amp and 4 channel pioneer deck. i was running 6"rounds in my doors and tweets in the dash off the front 2 channels of the amp with crossovers to the tweet. the back two channels ran only 2 8"subs.
i bought some 6"x9"s to add to my system and a friend told me that i should run all my speakers off my deck and only the subs from the amp. so i wired it all up, everything was skookum but when i started to put my deck back into my dash everything got smokey.
i blew the 10 amp fuse in the power supply wire for the deck and the main power for my amp just wont work. now with a new fuse my deck turns on but i cant get any sound out of it and my amp wont come on at all, even when i use a power line straight from the battery.
did i kill my system? do i need to replace my deck and amp?
Old Apr 1, 2009 | 07:33 PM
BigBluePile's Avatar
I know that my deck has a fuse in the back, does yours? I'd check that and all your wires. Does your amp have a "power" light on it?
Old Apr 1, 2009 | 07:47 PM
sinneDBTB's Avatar
a fuse other than the one on the power wire?
my amp had a couple of lights, none of which come on.
Old Apr 1, 2009 | 08:37 PM
Elton's Avatar
its that sony amp its junk
Old Apr 1, 2009 | 10:39 PM
sinneDBTB's Avatar
what's your beef with sony?
Old Apr 2, 2009 | 07:06 AM
drpdmazda's Avatar
sony xplod amps are very touchy and blow very easily. an easy way to test if the amp still works is do as you said and run the power wire directly to it, make sure the amp is still grounded and run a small wire as a jumper from the power terminal to the remote turn on terminal. if the amp powers up it is most likely still good, you may have just blown the remote turn on output on the head unit somehow. test the amp and post your results and i will try to help you trouble shoot
jason
Old Apr 2, 2009 | 07:07 AM
drpdmazda's Avatar
forgot to click the subscribe button
Old Apr 2, 2009 | 11:46 AM
sinneDBTB's Avatar
jason
thanks man, my amp is working. phew!
i cant get sound outta my deck still so i went and bought a new one and now i cant get it (the new one) to turn on. i had to get a pioneer so my 6 disc changer would be compatable. when i hook up power to the new deck i hear the disc changer and amp come on but the deck itself wont.
also the remote turn on wouldnt work with my old deck but it is fine with the new one. could that point to my wiring harness, i would way rather buy a new harness and take the deck back for the $315 i spent on it
Old Apr 2, 2009 | 05:51 PM
drpdmazda's Avatar
do your interior lights still work? check all your fuses with a multimeter, even if a fuse doesnt appear to be blown it can still be blown. your muti meter should have a picture of a speaker on it, with the fuse in the fuse block you will still see two small expsed pieces of metal on the back. put your positive to one tab and your negative to the other ( with your meter turned onto the speaker picture ) if the fuse is good it will make a tone through the meter, if its junk it wont. check all your fuses nder the dash and in the hood. another way to test the radio is take the red and yellow wires and twist them together, put the black wire on your battery ground and put the red and yellow on the positive, if the radio is in working order it will power up.
try those and let me know what happens
jason
Old Apr 2, 2009 | 07:28 PM
sinneDBTB's Avatar
no it wasnt anything other than my deck being fried. the new one wasnt grounding properly was the problem. everything is gold now i just have to get it tuned.
thanks though
Old Apr 2, 2009 | 08:16 PM
drpdmazda's Avatar
thanks though
glad to hear its working now. what type of deck did you replace it with?
Old Apr 2, 2009 | 08:56 PM
sinneDBTB's Avatar
pioneer premier gt600 i think.
its pretty sweet has a usb wire from the back for a direct ipod link and a aux line in. plus lots of other features i either dont understand or havent found.
thanks a ton for all the help. i am sure glad to have not had to buy a new amp too.
Marley2984
Dec 6, 2015 05:19 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
langry345
Sep 14, 2015 03:36 PM
ac7822
Sep 11, 2015 08:49 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
