New Alpine head unit
Yeah, I didn't think the Nissan adapter would fit. Possibly a delco/GM adapter, but I'd have to see it first.
Two questions rwmorrirson - kinda off topic, don't mean to hi-jack your thread, but how do you like your Revos? I'm kinda torn between the BFG ATs and them - leaning more toward the Revos.
~Bill
~Bill
From: Home: Aurora, CO; Work: The People's Republic of Denver
Hijack on- Go for the Revos, awesome traction in rain & snow, can't break them loose on dry pavement at all. Got rid of AT's for these & love them.-Hijack off.
Thread: looked at the GM adapter & it's the same size, but I need a female one of those & a female standard sized Motorola as Y-harness into a standard size Motorola male for the Alpine.
If the GM adapter will work for you, then go here:
http://www.installer.com/antenna/
and order the UV-43. This has two motorola female inputs that tie to one motorola input male. Then pick up a GM-10 to adapt the diversity antenna to the motorola Y.
Total cost - about $20. Note that every time you add a piece, be it an extension, a "Y", and adapter, or whatever, there is a slight loss of signal during the transition. Also not as elegant as a single cable solution, but I can't seem to find any of those anywhere.
A quick piece of advice for you though - before you order, pick up the mini-GM adapter from Wal-Mart to fit-check it. It may look the same, but actually be 1 mm different and not fit. After you fit-check it, then just take it back to Wal-Mart - they have the best return policies!
Hope this works for you - I think it's your best bet unless Ruizs lets you know where he got his adapter.
~Bill
PS - Thanks for the info on the Revos - I drive probably 85% street 15% off-road, so I think that I'm going to pick up a set for myself. Did you order them online, or find them locally?
~Bill
Thanks for the info, can get the GM one at PepBoys, will get it there & try it before I order the Y adapter. Awesome antenna site, BTW. As for the Revos, I got them at Tires Plus, but even Costco can order them in. I did it locally so I wouldn't have to deal with installation & old tire disposal.
#25
Re: New Alpine head unit
Originally posted by rwmorrisonjr
I just got a new Alpine head unit installed and the installer at Circuit City didn't hook up the diversity antenna. Is this okay, or should this be hooked up? If so, is there an adapter that will allow both antennas to be hooked up? If not, is this an excuse to do the Tacoma antenna mod?
#26
Re: Re: New Alpine head unit
Originally posted by Biff
Whats the Tacoma antena mod, sounds cool. Another mod for my runner to swallow.
kgcwb44
Jan 29, 2023 10:02 AM
themightykhoner
Aug 11, 2015 07:37 PM
