Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
installed new stereo,neep help
Old Apr 12, 2010 | 04:24 PM
pjb00stin's Avatar
hey guys,
im new to the forum. I just picked up a 2nd gen 4runner.all original,even the stereo.So I swapped it out for my alpine with cd player and ipod cable. When I turn it on, the radio works as it should in tuner,but when I turn to CD,music is only coming from the front speakers.=(
Anyone know whats wrong?I dont know if this happens with the ipod connected yet.thanks
pj
Old Apr 12, 2010 | 04:38 PM
yotaman85's Avatar
I hate second gen stereo problems...
Old Apr 12, 2010 | 04:50 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Run your own speaker wires to the rear speakers and bypass the factory wires.
Old Apr 12, 2010 | 05:09 PM
pjb00stin's Avatar
Is there something in between the rear speakers and stock unit?
thanks for the help
pj
Old Apr 12, 2010 | 05:18 PM
toylocost's Avatar
Im pretty sure there is. I just live with it. I have massive bass back there and it fills in most of the rears. Ive been tolt there is an amp between the HU and the rear speakers that does strange things that no one can explain.
Old Apr 12, 2010 | 06:50 PM
pjb00stin's Avatar
for sure.thanks for the help..Where should I run the wire through the truck? and what gauge should I get?thanks
pj
Old Apr 12, 2010 | 08:27 PM
toylocost's Avatar
Just go to walmart and get the cheap stuff if your just running sraight off the head unit. As for where to run it. I would zip tie one going to the passenger side behing the dash and one going the other way. Down behind the kick panels, pull the door sills, tuck under the carpet, same with the rear doors. Should be able to push it up behind the rear side panels, they start right next to the rear seats. From there it should be easy. But your pretty much gonna have to figure out the details I cant hold your hand the whole way. How would you learn?
Old Apr 12, 2010 | 08:38 PM
yotaman85's Avatar
it is much easier to run both wires from the head unit to behind the glove box,into passenger kick panel, under the door seals and split them up under the rear seat to each rear panel, then run them under the rear panels. this is not fun but the factory amp that is inside the rear panels is a pain in the ass to get to work and all the stock wiring is really small and shaty.
Old Apr 12, 2010 | 09:23 PM
pjb00stin's Avatar
cool thanks guys.you know the size of the rear speakers?as well as the front.I mite as well replace them. Thanks again!
pj
Old Apr 12, 2010 | 09:26 PM
70elcoss's Avatar
isnt the factory amp inside those black boxes the rear speakers are enclosed in?
Old Apr 12, 2010 | 09:27 PM
70elcoss's Avatar
the fronts are 4" and the back is too i think but a lot of people just drill a bigger hole into the speaker box to fit 6.5's thats what i did and it was a HUGE difference
Old Apr 13, 2010 | 04:19 PM
annoyingrob's Avatar
If it works fine in tuner, and not in any other mode, chances are you mixed up your antenna and aux power wires.
Old Apr 13, 2010 | 07:28 PM
toylocost's Avatar
I dont know what you mean? Aux power wire what is that? Going to where? What would it have to be connected to to create this symptom? I had this problem and traced my perfectly built harness with a multi meter. Every single wire I made was good. Yet still had the problem.
Old Apr 14, 2010 | 09:39 AM
pjb00stin's Avatar
i'll look more into this. When I swapped my head unit from my evo to my 4runner, I switched a blue wire with the blue with stripe I think,which is the amp turn on.
pj
Old Apr 14, 2010 | 04:45 PM
toylocost's Avatar
Well I have the problem and my sub amp turns on just fine. I crossed no wire. I don't have much faith it that theory lol.
Old Apr 15, 2010 | 04:07 PM
There are two power wires. One is blue, one is blue with a stripe. One of them is on all the time that your head unit is on, it's the aux power wire, and is meant to switch on amplifiers and such. The other is the antenna power wire, and is only on when the radio is on. Most old radios only had one aux power wire, the aux/antenna wire split is a new thing. Disconnect whatever your antenna wire is connected to, and connect it to the aux power wire, and your problem will be solved.
Old Apr 15, 2010 | 06:48 PM
ET's Avatar
ET
i had the same problem when i did mine. i just took apart my dash and took it to an audio shop in town and they fixed it for 20 bucks.
Old Apr 15, 2010 | 07:04 PM
toylocost's Avatar
My antenna wire is connected to my antenna. So your saying my antenna will be up all the time?
Old Apr 16, 2010 | 05:15 PM
It will stay up all the time the radio is on, yes. Chances are that the rear amp is ALSO connected to the antenna power wire, which is why the rear speakers aren't working when not in radio mode.
Old Apr 16, 2010 | 11:40 PM
toylocost's Avatar
Ok now that makes sense if there was ONLY a factory radio and NO tape player, but my truck is loaded, power everything, cruise, sunroof, V6, it had to have something other than a radio. Idk dude it's a weird problem.
