Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
front speakers in 94 4runner rattle
Old Jul 10, 2006 | 04:20 PM
BigSimps04's Avatar
I believe my 4runner's speakers in the front are blown or are about to. They always seem to rattle or vibrate loud when the volume reaches a certain point. I am not looking to put a system in, I would just like something that can handle quality sound at a loud volume. Any suggestions? Where would I find such pieces? Keep in mind price needs to be resonable.
Old Jul 11, 2006 | 07:50 AM
Calimus's Avatar
You should be able to get replacement at your local Circuit City, Best Buy or local sound shop. For $60-$70 you should be able to get a set of speakers that will more then handle the stock radio.
Old Jul 11, 2006 | 09:26 AM
Cebby's Avatar
The stock front speakers are junk. ANY aftermarket speaker would be an improvement. Look for an inexpensive "coaxial" speaker (it will have a separate tweeter on it).
Old Jul 12, 2006 | 01:44 PM
BigSimps04's Avatar
Thanks all, I will surely get into that and improve the speakers, does anyone know the sizes that would best fit the front? I was also thinking of getting the backs done, any recomendations? Thanks
Old Jul 12, 2006 | 11:01 PM
ricky's Avatar
go to crutchfield.com. They have tons of info on most any vehicle. Great place to do the homework, even if you don't buy from them. But if you do, they will give you everything you need to install whatever you bought, in the car you choose (car info, speaker wire harnesses, adapter brackets, etc.) for free.
Old Jul 14, 2006 | 08:36 AM
Beast's Avatar
i have had good luck with ebay for speakers
I like audiobahn
polk
infinity
your should be 4" but bubble check that
Old Jul 15, 2006 | 11:16 PM
Bumpin' Yota's Avatar
Yes, you have 4" or what crutchfield refers to a 4T. Basically a 4" speaker with only 2 mounting tabs.
As far as 4s are concerned, Infinity's are your friend!
Old Jul 17, 2006 | 06:55 AM
AJwhoisthat's Avatar
The front speakers in the 4runner (mine is a 1995) are different because (like said above) they have a different mounting structure thank most normal 4" speakers. So its eather fabricate a bracket or... i know Kenwood makes one to fit with the special mounting tabs on Crutchfield. Crutchfield only sells one speaker to fit that slot. Im sure other brands make a speaker that fits I just dont know where to find them.
Old Jul 17, 2006 | 09:57 AM
Blizzard's Avatar
No problem with fitting standard 4'' speakers, you only use 2 bolts of the 4 as Cebby said.
David
Old Jul 17, 2006 | 12:52 PM
Greg_Canada's Avatar
most speakers like my infinity's, you just have to bend two of the brackets off to make it fit.
I still found that it was alittle tight, the speaker had such a large magnet that it touches whatever is behind it (i think the heater ducts?) but i got mine tight in there and they dont rattle....
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
