Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
front speakers
Old Sep 18, 2011 | 06:11 PM
wolf28's Avatar
Question front speakers
my front speackers in my 89 toyota pick up arent the greatest every time i turn the volume up to 1/2 they start clicking real bad i seen another yota tech member just put a 6x9 on the outside of the speacker vents wat do i need nd how can i upgrade these stock ones
Old Sep 18, 2011 | 06:25 PM
Tofer's Avatar
Sponsor
I would just get a good set of 4" speakers and keep it clean. I hate it when people hack up the Saskatchewan to install 6x9s....
Old Sep 18, 2011 | 06:29 PM
wolf28's Avatar
i messed it up they where 4x6s just screwed onto the speacker vents
Old Sep 18, 2011 | 06:46 PM
wolf28's Avatar
so if i got 4 icnh and installed them what would i need
dam i wish i knew more about speakers
Old Sep 19, 2011 | 11:18 AM
wolf28's Avatar
any help
Old Sep 19, 2011 | 01:29 PM
2ShotTuck's Avatar
ive replaced a couple, you need to tear apart alot of the dash just to get to them. it sucks and it was a pain in the butt for me to figure it out but it takes a philips screw driver and a 10mm socket to take apart the dash, the ones ive done had a plastic box to cover the speaker and it acts as a box to amplify the sound and yield better qualities. but there should be a kick pannel on both sides, that comes off with the socket, then look around for screws, 2 or 3 are in the jockey box, one is under your E brake. its pretty simple, your going to have to use some force to get the plastic off, its nerve racking if your concerned about breaking it. those boxes i told you about earlier use 4 specific screws to take them off, dont loose them, then there are 4 screws holding the speakers in.
sounds like a ton of work for 2 little speakers but for me it takes about 15 minutes, first time it took me close to an hour because i was learning. its a breeze when you've done it twice the oldest toyota ive done this on was a 90, yours could be different
Old Sep 19, 2011 | 05:27 PM
wolf28's Avatar
so i got a friend who can get me some 4 insch speakers so basically he'll istall them for me basically cut and go right
Old Sep 20, 2011 | 06:06 AM
drpdmazda's Avatar
there is no cutting involved in installing new speakers, if your friend suggests cutting, run away.
google is your friend, this was the first thing that popped up when i searched "speaker install in a 1995 toyota". this is a walk through on how to do the radio, but the process to remove the radio is very similar to accessing the speakers, now is a good time to replace the radio if you have not already and were thinking about it, since your dash will be disassembled.
the only materials you should need would be some speaker harnesses, you can get them at a local install shop, best buy etc. they will plug right in to the factory plug and clip on to your new speakers, keeps it simple with no cutting wires.
good luck
Old Sep 20, 2011 | 06:47 AM
wolf28's Avatar
i was thinking cut old speackers out and connecting the new ones
Old Sep 20, 2011 | 07:55 AM
drpdmazda's Avatar
my question is why? why would you cut up a clean looking dash to add speakers? if you take a good look at the location of the front speakers, you will notice that even the small 4" speakers they have in there already take up most of the available space. you may be able to squeeze a 5.25" in there, but in my opinion, the amount of work it would take versus the amount of sound you would gain wouldnt be worth it.
lets start fresh, what are you trying to accomplish here?
Old Sep 20, 2011 | 09:58 AM
wolf28's Avatar
i guess nothing now im buying 4 inch speakers and having my other friend install them at his car audio shop
Old Sep 20, 2011 | 10:36 AM
drpdmazda's Avatar
what i meant by that was what are you looking to do, more sound? as in a bigger speaker, or just a factory replacement size for the old blown ones? if you have a friend that has an audio shop, go over ooption with him to cut some 6.5" speakers into the doors. larger size, more options and possibly even amplify them at a later date.
Old Sep 20, 2011 | 02:41 PM
wolf28's Avatar
i just wanna replace the blown stock ones idc about how loud the speakers get im confused at why i cant cut the old ones out and just wire up the new ones itll cost me 20 bucks that way instead of 75 and getting the done at the audio shop
Old Sep 20, 2011 | 03:36 PM
drpdmazda's Avatar
if you want to cut your tuck all, by all means dont let me stop you. i gave you the step by step on how to take them out, which would not require you to pay anyone. the money you save could be invested in better speakers. but again, if you want to cut, cut away.
Old Sep 20, 2011 | 03:41 PM
wolf28's Avatar
im not talking about cutting the dash or anything im talking about cutting the wires off the old speaker and just wiring up the new ones
Old Sep 20, 2011 | 05:39 PM
drpdmazda's Avatar
oh, i thought you meant cut into the dash, as in sawzall a new hole for the speakers, thats why i was so confused. the wire colors should be:
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
your new speakers should come with some pre terminated wires. splice those in with the wires from the vehicle and you should be good to go
Old Sep 21, 2011 | 11:37 AM
wolf28's Avatar
thanks buddy
Old Sep 21, 2011 | 05:31 PM
wolf28's Avatar
took em apart today and there just a feale and male connector
Old Sep 21, 2011 | 05:35 PM
ChefYota4x4's Avatar
I put some Blaupunkt 4" 3-ways in place of the stock blown ones, ...and while they're not INTENSE, they put out GREAT highs and mid range... So I just adjust to Fader-1-Rear(to my 6x9's) and then the sound is REALLY clean, even with an old super tuner. EASY swapping in new 4"ers where the old ones were.... no need for an audio shop, neither lol.
Old Sep 21, 2011 | 06:10 PM
wolf28's Avatar
that foam outer ring is like disinegrated in mine there so old
