Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Flamedx4!.....got the sub installed.
Old Jun 18, 2004 | 05:50 AM
DavidA's Avatar
I removed the cargo door on the bench seat, right behind the drivers side, like your install. I then made a new cover out of plywood, cut the woofer hole, took hardware cloth/mesh and covered the hole to provide protection for the woofer in case my kids try to sit on it. I then mounted the woofer and covered the top with carpet.
What did you do to isolate it from the other compartment area where the jack is stored? I used foaming insulation to make it airtight. Sounds pretty durn good...I still have to add some more insulation to fill some cracks. The Rockford Fosgate manual said I need just under 1 cu. foot in order to achieve good flat response.
Thanks for your pics...they helped me visualize the process. I will try to post pics later.
seab1209
Sep 3, 2015 05:41 PM
agrout
Aug 13, 2015 06:12 PM
ripp96
Jul 31, 2015 11:14 AM
Yota.Jay
Jul 26, 2015 05:50 PM
SMOD
Jul 23, 2015 10:29 PM
