Do I need 3 pre-amp outputs?
I am going to buy a new CD player for my truck ('00 4runner SR5). I am most likely going to go with an Alpine unit. My question is do I need 3 outputs or will 2 be sufficient. The most modding to the stereo I imagine doing in the future is probably new mids in front and a basslink. Thanks -James
It's according on what the preamp outputs are. You'll want a sub output aka non-fading, and a front output. If you plan to adjust your front/rear fade (make the fronts louder than the rears and vice/versa) then you'll need a rear output also.
edit: and that's only if you amp the front and rears. If you plan to run them all off of the deck then you wont need to worry about front/rear outputs, but if you plan to run the mids/highs off of an amp then what I typed above applies.
It's pretty nice. Once you get it in give your review on it, i've been considering getting a new head unit cause mine skips more than a 3rd grade school girl when i'm driving around here. Half the roads I drive on are gravel so yea...
I would absolutely recommend this unit for the $$. I compared it to the Alpine which is a step up (plus $150) and other than a semi-colored display there seems to be very few differences. You can't really read the buttons on the headunit but it takes all of 2 minutes to learn where everything is.
justdifferentials
14
Jun 11, 2017 08:36 PM
sonorn67
Sep 19, 2015 05:39 PM
