Awwww Fudge
Awwww Fudge
Man I'm bummed. Yesterday I was driving home and no more bass. I listen to metal mostly so I don't need a ton of lows, but my little sub has worked for me for 5 years. It's a 75 watt kenwood tube with a 10" in it. I tested the voltage with my meter right at the plu connection. There's power up to it, but It just won't turn on. I think I fizzled the amp. Bummer. Any suggestions on how to check this thing otherwise. I'm saving for a lift and I would rather just get this going right now. Thanks -Seth
It's a little more than loose speaker wires I'm afraid. The amp section does not even come on (No light, No sound). I got 12v from the constant as well as a reading on the turn on lead. I have a 15 amp inline fuse (It's fine) and a 15 amp fuse on the amp (also good). I am confident at soldering, as I do a lot of Custom guitar work. Unfortunately I am unsure how to tell what is the problem unless it is scorched, even then it may be difficult to find parts for this thing. I will open it up today and see. I like that it's compact and sure hope that I can get it working again. thanks for the suggestions -Seth
YESSSS!!!!
I fixed it. I checked the remote turn-on before and it had a readout, albeit small. But your comments made me check again and there was nothing. I looked under my dash and it looks like my parking brake yanked it out of a butt splice. Looks like zip ties are in order. Everything works again. Thanks for all your suggestions.-Seth
OTOC
Mar 20, 2013 08:25 PM
