Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
active noise cancelling ideas
Old Oct 5, 2010 | 06:23 PM
91diesel's Avatar
So after getting a set of the Active Noise Cancelling (ANC) headphones for my wife I'm interested in trying it in my 91 pickup. I've read and understand the problems associated with ANC once you start getting more than 2cm away from the ear. I am curious though if you placed the microphone in the headrests if you could frankenstien a set of ANC headphones into the speaker system and quiet down the interior some. I'm not dumb enough to think it'll be silent but even if I could drop the noise by 5-8 decibels I think that would make road trips much nicer. I am also going to finish putting in sound dampner in the truck, I've already done the doors, floor and rear wall. Any thoughts?
Old Oct 5, 2010 | 06:55 PM
MudHippy's Avatar
It's been done...
Noise cancelling tech comes to car interiors
Toyota uses headphone technology to make ride quieter
By J Mark LytleJune 23rd 2008
Just like posh headphones, posh cars now have better acoustics too.
The principle behind noise-cancelling headphones is as elegant as it is simple – sample the noise to be cancelled out and use small speakers to create an equal, but opposite, sound that erases the problem.
Now, Toyota has taken that concept and applied it to one of its high-end hybrid cars, in a concerted effort to reduce interior noise for the comfort of passengers.
Low frequencies
The company's 'Active Noise Control' system appears in the new Toyota Crown Hybrid car and reduces the noise inside the vehicle by up to 8dB. It was implemented after the car's engine was found to be noisier than expected as it rotates more slowly for better efficiency.
Toyota discovered that the low-frequency noises given off by the engine were more audible than in other cars with similar equipment under the bonne. The company tackled it by first adding three interior microphones to listen in on cabin conditions.
Engineering challenge
Then, it installed three speakers – on the front doors and the rear shelf – to play back the cancelling signals. The car's music system can still be used at the same time, of course.
Although describing the system like that is relatively simple, the acoustics inside a car made getting it right a challenge.
Unlike headphones, the in-car system has to deal with both direct noise and its echo when it bounces off interior walls. The result is a system that cancels out the engine sounds around head height – precisely where our ears are, in other words.
http://www.techradar.com/news/world-...#ixzz11XkfP4Uy
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
