Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
98 SR5 Stereo Harness
Old Aug 24, 2006 | 06:16 PM
Joe3's Avatar
Just opened up my dashboard and tried to install an aftermarket stereo in my new 4Runner. Had the wiring harness I purchased at NAPA hooked up to my stereo but when I went to hook it up to the stock harness, it didn't fit. In fact the pins dont even look like they are the right size (too big). I bought a Universal harness for 1987 and up toyotas? Not sure exactly what to do here...Where would my best bet be to get the right harness? Has anyone else had this problem?
Old Aug 24, 2006 | 06:19 PM
Localmotion's Avatar
I dont think they are universal. You can go to a stereo shop to find a harness...or you can splice wires.
stereo shop would be good, or even best buy?
Old Aug 24, 2006 | 06:22 PM
wjwerdna's Avatar
where are you located? Best Buy has them, Circuit City has them, so does PepBoys and many other Auto Chains, along with Wal-Mart, the reason i asked location is that Meijers has always had what i needed too (MI shopping chain, kinda like wal-mart, but cool)
Old Aug 24, 2006 | 06:24 PM
garrett1478's Avatar
i bet crutchfield can hook you up.
Old Aug 24, 2006 | 06:43 PM
Bob_98SR5's Avatar
joe,
welcome to YT
first, please post these kinds of questions in our stereo forum. second, check the tech section. there are two writeups that address your question re harnesses and they have part #s and install instructions
bob
Old Aug 24, 2006 | 08:07 PM
profuse007's Avatar
look at the harness again and trace it back, there might be a second set of harnesses.
Old Aug 24, 2006 | 08:10 PM
Bob_98SR5's Avatar
sounds like you didnt unhook the amp. check out the tech section's writeups for your stereo install
bob
Old Aug 24, 2006 | 09:47 PM
bigacuralvr's Avatar
Search. You need to unhook/remove the amp. The wires are hooked to that. Most of Toyota stereos use the same harness, including the 4Runners from 87-02.
Brett
Old Aug 25, 2006 | 03:00 AM
Bumpin' Yota's Avatar
hehehe no worries! In most post '94 4runners, toyota put OEM amps in to boost power to the speakers. You can either try to incorporate this amp using and amplifier integration harness which will plug into that pigtail you found (Met 70-8112 is the part number) Or you can just bypass the OEM amp. Lucky for you the OEM amp should be right behind and slightly below the main radio on its own bolted in brackets. Youll notice there are two sets of pig tails going into that amp, and one coming out to the back of your origional radio. Unplug those 2 pig tails then plug em into the harness you bought. When done you just bypassed the OEM amp and are done!
Old Aug 26, 2006 | 03:04 PM
Elton's Avatar
i got a stereo harness from a stereo shop and it fit perfect i used it with my 91 and its now in my 98 ... just unplug the stock amp and it will fit
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
Esibnitsud
Jul 30, 2015 08:19 PM
dfarr67
Jul 30, 2015 07:08 AM
88yodabasket
Jul 13, 2015 01:32 PM
