Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
91 runner, head unit
Old Feb 24, 2007 | 06:26 PM
GMJK86SR5's Avatar
I would like to replace the stereo, in this truck. I would like something inexpensive, and all I need is a single cd with and input for futrue mp3 player.
How do I get the dash apart? What player should I get? Are there upgrade 4" speakers for the fronts? What to put in the back speaker spots?
Thanks Mike
Old Feb 24, 2007 | 06:36 PM
Elton's Avatar
how to get the dash apart http://www.installdr.com/InstallDocs...PDF/869017.pdf
for a good deck cheap and simple
http://www.millionbuy.com/piodehp2900mp.html and the harness
http://www.millionbuy.com/a-itwh950.html
Old Feb 24, 2007 | 07:22 PM
GMJK86SR5's Avatar
Eton,
You are the man. Great info. I think I will be able to do this now. Do you have any ideas about goo inexpensive speakers? 4", rears?
Thanks again,
Mike
Old Feb 24, 2007 | 07:41 PM
Elton's Avatar
whats the most your willing to spend on the 4 speakers
Old Feb 24, 2007 | 10:31 PM
GMJK86SR5's Avatar
close to 100. Can that be done?
Old Feb 24, 2007 | 10:54 PM
Elton's Avatar
for the front http://www.millionbuy.com/inf4012i.html no clue what the rears are
Old Feb 24, 2007 | 10:57 PM
rezrunner92's Avatar
The rears in my 1992 Runners are the same size as the front. They are in boxes though. The one on the left side looks like it maybe could be modified for a little bigger speaker.
Old Feb 27, 2007 | 07:38 PM
GMJK86SR5's Avatar
I was in Walmart and found a Pioneer 2900 packaged with some Pioneer 5.25 for $78. So I bought it. Now I have it installed, but the fade does not work or the rear speakers don't work. Any suggestions?
I bought the adapter that walmart had for on 81 and up truck. The plug in the truck, for the rear speakers, has four pins and one more in the middle. The adapter from walmart has four pins for the speakers, but not the one in the middle??
Any help is appreciated.
Mike
Old Feb 27, 2007 | 07:51 PM
glenyoshida's Avatar
The rear speakers may have an amplifier on them. With a digital multi meter you can check the speaker wire resistance from the deck to the rear speaker. If you have a high resistance above say 1 ohm or a no reading then it's a good indicator that you have a factory amp.
Old Feb 27, 2007 | 07:52 PM
Elton's Avatar
https://www.yotatech.com/forums/show...=rear+speakers
https://www.yotatech.com/forums/show...+sound+antenna
Old Feb 27, 2007 | 08:49 PM
GMJK86SR5's Avatar
Well thanks agian. What incredible info. It is up and running.
Mike
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
voiddweller
19
May 2, 2016 09:10 PM
deuxdiesel
Jun 20, 2015 02:49 PM
