Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
88 stereo no power
Old Jan 30, 2008 | 06:36 AM
Magoo's Avatar
88 stereo no power
so i bought a truck over the weekend.
previous owner tells me he had a radio in it at one time and he just pulled it to put in another car.
it has all the factory connectors.so i go to wally world and get the connector/adapter deal.then hook it up to the appropriate wires,turn it on and no power.
i tried with 2 different known to work head units and all fuses are good.
what gives? am i not looking in the right spot for another blown fuse?
didnt have time to find my test light last night,just got frustrated and walked away.
Old Jan 30, 2008 | 07:37 AM
sdstud212001's Avatar
test lamp
Old Jan 30, 2008 | 04:24 PM
89macrunner's Avatar
probably a bad connection to your battery or ign line. get a multimeter!
Old Jan 30, 2008 | 09:16 PM
fullmann's Avatar
check and see what wire at the deck location is dead, if its the constant wire, the fuse is under the hood in the secondary box.
Old Mar 20, 2008 | 04:50 PM
RiNkY's Avatar
I'm having a similar issue. Checking with my multimeter none of the wires that the old stereo hooked to is putting out any voltage, with and without the ignition on.
I checked every fuse in the damn rig - in the engine bay and in the drivers foot well and all of em are good. I think I'm gonna have to run a couple of new wires from the ignition cylinder around to the Stereo.
Any suggestions what I might be missing, is there a mystery fuse someplace else?
Old Mar 20, 2008 | 05:00 PM
RiNkY's Avatar
Thinking about it (I'm not very electrically minded) - I guess a wire directly from the ignition would be a bit silly.
Would running fused power straight from the battery and through the firewall, then run the + when ignition is on from the ignition cylinder work?
Old Mar 21, 2008 | 07:26 AM
fullmann's Avatar
RiNkY-
check all of the fuses under the dash and at the battery under the hood with the key on. I have yet to see a fully dead wire on a toyota.
if they are truely dead, you can get switched and constant at the ign switch. on most vehicles with dead power wires, thats usually where I get my power.
r3dfish
54
May 16, 2016 10:31 PM
theking11863
Mar 19, 2016 09:36 PM
skoob
Oct 15, 2015 03:23 PM
corey519
Aug 12, 2015 11:12 AM
Esibnitsud
Jul 30, 2015 08:19 PM
