Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
3rd gen Radion
Old Aug 30, 2005 | 01:22 PM
Lone4runner's Avatar
3rd gen Radion
I ws pulling apart my radio a realized that on the back of the factory there were 2 radio?? wires. can someone please help
Old Aug 30, 2005 | 02:00 PM
DavidA's Avatar
Do you mean the Diversity Antenna cables?
Or the dual power and speaker plugs?
Old Aug 30, 2005 | 02:17 PM
well one of them looks like the antenna wire which im almost postive of. The other is smaller next to the antenna wire. i have a 99 limited 4runner.
Old Aug 30, 2005 | 05:32 PM
DavidA's Avatar
I believe that is the secondary antenna AKA Diversity/Secondary antenna. You can ignore that when installing a new radio.
Old Aug 30, 2005 | 09:08 PM
noahrexion's Avatar
I have two questions regarding this matter...
first off I have a 1997 SR5 w/6 speaker deal
I also have the two things and the deck I bought (pioneer deh-80mp) actually has fittings for both of these plugs. I assume to use them but I had no idea there were two seperate wires for the antenna (kinda weird).
Secondly I went to install my speakers in teh front door today and I am a little puzzled as to which wres to tap into. One harness looks to come from the front of the car and be the main, the other one goes towards the door handle.
My assumption is that they run both the factory tweet and and the woofer from the same signal and that one of them is the one running to the factory tweet.
So heres my question... I know I can easily look and see which goes to the tweet and ignore it. However I am installing some 2-ways up front and was wondering if I should wire the factory tweet into the new 6.5" kappa's I will have up front and run it like factory. Or if I should just leave it alone as the Kappa's will sound way better anyway, expecially since they are 2 ways and have a tweet already.
TIA,
austin
Old Aug 31, 2005 | 06:19 AM
Bumpin' Yota's Avatar
Leave the factory tweet alone. Wiring it up series or parallel to the infinity tweet on the crossover will radically change the crossover points....(very bad)
This install is very easy actually - just make sure that the 6" mid is playing full range, if so just tap into the 2 wires feeding it for the signal for your infinity components.
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
