Welding brackets to axle
Old Aug 26, 2006 | 11:22 AM
Beast's Avatar
Please DO NOT post miss information
Who know hard fax on welding to your axle beyond basic good welding practice (cleaning and grinding)
Is there a specific wire to run.
this is for my Four link so please don't post false info!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 26, 2006 | 11:37 AM
superjoe83's Avatar
if your still running Toyota housings you dont need anything special, just dont weld too much at one time to avoid possible warping
Old Aug 26, 2006 | 04:58 PM
MossyRocks's Avatar
I've been doing some looking into that because of torching off old brackets and welding on spring perches and the like. I've come up with it a few things
1: The axle needs to be assembled
2: Weld a small portion of one on one side and then go to the other side and do the same, just and inch here then a inch there while alternating sides to keep the heat down.
3: I'd like to know if its better to do it with oil in it for the heat to take longer to spread or if it should be empty to help dissipate better (someone who knows needs to chime in on that part because I've heard people preffering it both ways)
nvdesertrunner
May 11, 2020 08:18 PM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
shisha1999
Aug 14, 2015 01:33 AM
priest16
15
Aug 6, 2015 07:43 AM
