Trail Gear sliders....
Old May 12, 2007 | 05:09 PM
OSU4Runner's Avatar
I bought a new set of Trail Gear sliders, getting ready to have them installed when I get my truck back. I have called a few off road shops and one place quoted me $100, the other $75....My last set, I had a buddy install them in Ohio. So do these quotes sound decent for the job at hand?
Old May 12, 2007 | 05:13 PM
HuskyRunner's Avatar
When I looked into sliders, the local 4x4 shop quoted $75 per side to install, and that was after buying the sliders from there as well.
Fink's Avatar
If that includes all the measuring, cutting, lining up, re cutting, and welding then yeah $75-$100 sounds pretty good.
I had a buddy do mine and it took us quite a while to get em on.
Fink
Old May 12, 2007 | 06:25 PM
waskillywabbit's Avatar
Install a set yourself and see how long it takes you to do it "right"...then see if $100 is worth it to you. Actually welding them on takes 15 minutes maybe and is easy...it is all the other stuff that must be done that takes time and effort to be done right.
Slider install at a minimum is a $100 job for me and that is for someone who buys the sliders from me, or it isn't worth the time or hassle.
Old May 12, 2007 | 06:34 PM
OSU4Runner's Avatar
I wish I could.........I dont' know how to weld and I don't wanna bolt them on
Old May 12, 2007 | 07:33 PM
Fink's Avatar
Brian's right. The welding is the quick part. It's all the prep you have to do before the welding to be sure they're perfectly level and evenly spaced.
I would say $75-$100 would be a great price.
Fink
Old May 12, 2007 | 07:34 PM
OSU4Runner's Avatar
Coooll thanks for the help!
Old May 12, 2007 | 08:05 PM
rrmike's Avatar
Spend a couple more bucks and have them plate at least the end two legs. I mean plate the frame where they attach and maybe gusset them a little. I just cut a couple small triangles per side from some 3/16 2" flat stock.
It will double the amount of vertical loading they will take before ripping loose from the frame.
Old May 12, 2007 | 08:49 PM
OSU4Runner's Avatar
I bought a gusset set for these from trail gear
Old May 12, 2007 | 09:08 PM
d0ubledown's Avatar
my TG sliders were about CDN$300 or so installed at bigcountrycustoms. figure about $175 of that for the sliders themselves...and 125 for the install. brians right...spend the $150 or whatever it takes. when welding to the frame...esp something like sliders should be done right. once.
XtraCab
Apr 12, 2020 05:25 AM
Scotto6591
Sep 1, 2015 03:24 PM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
msane99
Jul 27, 2015 06:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
