Thaught i would show my remote turbo setup.
Old Apr 11, 2008 | 07:54 AM
zlathim's Avatar
It is a cool setup though Dustin- Keep at it until you get it to function well. If you set it up as a completely remote oil system, make sure that you can monitor the oil pressure in the cab.
Old Apr 11, 2008 | 08:08 AM
Dustin Songer's Avatar
Thanks, thats a good idea, ill do that.
cutboggers's Avatar
why the bed location???? simply for space or what?
Old Apr 11, 2008 | 08:48 AM
A few things. On of my main concerns was overefficiency. Yeah it sounds weird but i didnt want the turbo to be spooling like crazy, i only wanted the boost when i needed it. So a remote setup seemed like a good idea, then, i put it in the bed to keep it out the water when im in rivers and whatnot, and it was an easy place to put it. Im not using that space for anything so why not? haha
Old Apr 11, 2008 | 09:33 AM
  #25
aviator's Avatar
It'd be a pain but you could put some kind of by-pass valve in the exhaust, old time hot rodders used to do it, basically with the valve in one position the exhaust flowed through the system and in the other it went straight overboard out of the head pipe for drag racing. In your systm it would just flow through the turbo or not. If you used a double valve [before and after the turbo] you could prevent back-flow and just use the one tail pipe but it would be a very complex system then.
Old Apr 11, 2008 | 11:17 AM
  #26
Haha, key word being complicated. I was thinking of doing the bypass setup but i figured that the boost wouldn't come on to soon. I did this mostly just to see if i could and to get a couple horses out of the old thing. But i mostly wanted to know if you could boost a carb without modding it, a knowledge expander if you will.
Dustin
Old Apr 11, 2008 | 12:31 PM
  #27
camo31_10.50's Avatar
wouldn't running a turbo be harmful on that lil 22R..like on the internals..since it wasnt built to run a turbo...or would it matter?...if i can im gonna either swap in a 22RET/R151F or a cummins 4BT with a VERY strong tranny...not sure what tranny to use..anybody know of a REALLY strong 5spd tranny..that will fit my '80 toyota...like dimensions...it doesnt have to be a toyota tranny..thanks!..sorry bout the hijack
Old Apr 11, 2008 | 01:47 PM
  #28
as far as trannies go i dont know, im happy with my 4 speed. But almost any engine that has a good reputation for being strong can take up to 6 or 7 lbs of INTERCOOLED air. The only reason im not using an intercooler is because: 1. i dont have the little one off my audi yet that i want to use and 2. there is so much distance the charge air has to run through the air is cooled off enough by the time it gets to the engine and 3. you realy have to put your foot in it to get more than 4-5 psi. Im pretty sure im blowing some crap by the rings right now but i need to do a good tune up on the engine and putting better rings in there wouldnt be a bad idea.
Old Apr 11, 2008 | 01:50 PM
  #29
Dont take that as the final word in turboing an engine, i have a nickname among my friends and its NST (nothing's sacred tuner) because of my lack of caring for whats supposed to work and whats not supposed to. I have a tendency to blow up engines. so dont go turboing your wives camry like this.
Old Apr 14, 2008 | 06:07 AM
  #30
unclejstoy's Avatar
I have seen remote turbos kits and was gonna pat you on the back for your engineering.
But after reading your comments......... are you that rich and board you can just go blowup moters and not care ??????
I don't understand
Old Apr 14, 2008 | 12:44 PM
  #31
no, im not rich at all. thats the problem. I havent realy blown up to many motors, i think 3. and they were all in my z. Those motors were all blown while i was on leave, cuz i spent 2 years in italy and a year in afganistan so i would push it every time i was home. What nst means is that when it comes to something thats not supposed to be done, i try to engineer a way around it to make it work without worring about little things like a blown engine. engines arent that expensive and the knowledge i gained from every engine was invaluable. I repeat, i am not rich. ( i would have a oil system for the turbo already if i was.)
Old Apr 16, 2008 | 05:09 AM
  #32
unclejstoy's Avatar
i wasent trying 2 bust yo balls i was just wondering. Thx for explaining the other moters.
But no oil 2 turbo bad. hell thats the only thing i don;t like about a remote kit.
all that moter oil traveling so far away from the moter. definitely need a oil pump upgrade.
Old Apr 16, 2008 | 05:15 AM
  #33
Well thanks then. As far as the oil is concerned, that would be a rediculous distance for the oil to travel and your oil pump would lose alot of precious energy in doing so. Thats why im building its own remote oil system with its own oil source in the other side of the bed and then i will just have an electric pump of some kind moving it to trhe turbo and back
Old Apr 18, 2008 | 05:06 AM
  #34
TruckAddOns's Avatar
Impressive fab work.
Old Apr 18, 2008 | 01:21 PM
  #35
Well thank you, thats very flattering coming from someone who deals with profesional products daily.
Old Apr 22, 2008 | 10:32 AM
  #36
Napoleon047's Avatar
You should have run the engine feed pipe under the passenger side of the truck. As for your oil pump: http://store.summitracing.com/partde...5&autoview=sku
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Ronnyboy
Feb 11, 2016 05:57 PM
mountainbrew
Diesel Swaps
Sep 20, 2015 07:12 AM
Ilovemountains
Sep 15, 2015 04:17 AM
shalom
Sep 8, 2015 10:02 PM
