Solid Axle Swap Has Begun!!!!!
Old Dec 29, 2005 | 10:44 AM
  #81
93ToyKid's Avatar
Yea she has a three inch body lift. As for the driveshaft, we have it working fine now. Ours is the exact same setup as yours is: auto with one transfer and manual hubs. The driveshaft uses the stock CV up top, and a regular U-joint at the bottom. A CV off of an 84 or 85 has more clearance and will work better, but ours seems to be working. It may need some help from the dremel, but it's not going to bind up unless the front end is completely off the ground. It doesn't vibrate in 4WD on the road. Ohe thing that helped is that the axle is moved 1-1/2 inches forward from stock. You can mount the front hanger to run the axle in stock or forward location. Anyway, good luck with your build! The driveshaft is the hardest part...
Old Dec 29, 2005 | 10:47 AM
  #82
93ToyKid's Avatar
BTW...at one point we had a U-joint at both ends and it provided less clearance than the CV up top. It wouldn't even angle enough for us to get it on! So we had to punt again and put the CV back on. Also, our front axle is shimmed about 1/4", so that helped tremendously without messing up the alignment.
Old Dec 29, 2005 | 12:23 PM
  #83
4rnr's Avatar
HMM I guess ill just have to throw it togeather and see what happens. I have a noncv front shaft and a cv front shaft off a 97 runner. This is lame I just want a drive shaft to mainly be used for just offroad.
Old Dec 29, 2005 | 01:09 PM
  #84
93ToyKid's Avatar
I know what you mean. Ours was a real headache. You never know exactly how it will work until you slap it on and then go twisting the front end around. When we had U-joints put on at both ends we were sure it was going to work fine and you couldn't even put it on. Good luck with it!
Old Feb 5, 2006 | 07:57 AM
  #85
93ToyKid's Avatar
Still have the IFS 3rd with 488s and a true track left if anyone interseted
Old May 19, 2006 | 03:47 PM
  #86
Toyota dad's Avatar
Very Nice Truck-----
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
Backcountry411
Jul 24, 2015 08:06 AM
scottyg486
Jul 19, 2015 05:34 PM
