Skid Plates??
Old May 9, 2008 | 08:55 AM
Mikeyb's Avatar
Skid Plates??
Hey everyone, this is my first post and i'd just like to say that this is a great site with a lot of knowledgeable people (or at least it seems that way). But, my question is what thickness of metal do you all think would be appropriate for some skid plates? I ripped one off today and figured that i would just make some new ones. I have a '00 Taco, so if anyone has any advice or words of wisdom, i'd appreciate them. Thanks.
Old May 9, 2008 | 08:58 AM
fillsrunner4's Avatar
Welcome
Ide say dont go less than 1/8". Its plenty strong for some mild abuse and if you want over kill go with 3/16" I use both on my rock crawler
Old May 9, 2008 | 09:05 AM
Mikeyb's Avatar
wow, that actually seems awful thin, i was thinking around 3/16" with some banding for support running laterally across it. do you think that'd be overkill? and also, would it be extremely hard to bend, or would i just add a little heat and i'd be on my merry way?
Old May 9, 2008 | 09:11 AM
What skid plate are you building? 1/8" is pretty strong. With some cross banding your talking about the 1/8" should be fine enough but it would never hurt to add a thiker piece in if your really worried or plan on having really hard impacts. My tranny skid I built uses 3/16" and my gas tank skid is 1/8".
hurley842002's Avatar
Honestly I don't think there is such thing as overkill when your talking skids, now of course weight becomes a factor, and since yotas aren't known for frame twisting horse power you would have to take that into consideration. 3/16" should be adequate.
Old May 9, 2008 | 09:17 AM
seanz0rz's Avatar
Guest
remember that 1/4 inch thick plate steel will weigh about 11-12 pounds/square foot. 1/8th inch thick plate steel weighs about 5.5 pounds/square foot. 3/16 will be just under 8.
i would go with engineering over more material, and strategically brace the plate, build in fail points, etc.
the idea of a skid is to protect vital components and to reduce the likelihood of being hung up on something. mine stockers are toast, and this summer will see some carefully designed 1/8 inch thick plates underneath.
Old May 9, 2008 | 09:43 AM
tc's Avatar
tc
Mine are 3/16" and they're bent pretty good in places.
With steel prices and availability today, unless you are buying big quantities and have the equipment, I would highly recommend just buying some from an experienced vendor like www.budbuilt.com
Old May 9, 2008 | 07:28 PM
Mikeyb's Avatar
thanks for the advice guys
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kawazx636
Sep 29, 2015 08:22 AM
Aaronmarston
Sep 22, 2015 09:39 PM
AlexJet
Sep 14, 2015 09:00 AM
